Question about Frigidaire Affinity ATF7000E Front Load Washer
Water does not enter washer - Frigidaire Affinity ATF7000E Front Load Washer
  • Frigidaire Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Posted on Jan 18, 2013
  • Richard Tripp Jan 18, 2013
    So is this a replacable part or how shall I check it?
Water not entering washer at start of cycle
check to make sure water is on if so then turn off all water and disconnect water hoses from back of washer, clean the screens that filter the water entering the washer
Aug 17, 2015 | Washing Machines
Frigidaire front load washer starts the cycle but no water enters the washer
Hello friend, I appreciate your post!
Based off the information you have provided water is not entering your Frigidaire washer. Are the house valves turned on fully? Check to make sure that the house valves are turned on and if they are check to make sure the water hoses are not kinked or pinched.
The problem could be within your water pressure, pressure switch, or water inlet valve. I would recommend reaching out to a professional for further assistance regarding your washer to avoid any unnecessary part purchases. I hope this has been beneficial. -Matt
Oct 12, 2014 | Frigidaire Washing Machines
Kenmore won't fill with water
Make sure your water valves are turned on. Check for blockages in the rubber hose and especially where the water enters the washer. Sometimes the chack valve of a washer can collase and restrict the flow of water entering the washer. It is usually located just beyond where the hose connects to the washer. Metal screens can clog and stop water flow. Check and replace as necessary.
The electronics of the washer may also not be advancing to the point where it allows water to enter, The main dial may be faulty. Check and verify all washer settings also
Aug 04, 2012 | Kenmore 4.5 cu. ft. High-Efficiency...
Whirlpool ghw9150pwo flashes FH
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the screens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean, check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Oct 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine keeps flashing up fh and not working
GENE
Oct 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an HF reading on my front load washer, water is going in and out. What could be the problem?
GENE
Sep 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The initials FH keeeps comin up on screen when the wash is at 26 minutes Then I have to turn off power and press start button again. What do these initials stand for?
GENE
Sep 12, 2011 | Whirlpool AWM6100 Front Load Washer
No warm or hot water entering washer
Clean inlet filters for water supply hoses coming into back of washer. There two small screens on the inlet fittings, "back of washer" that must be removed and cleaned once yearly.
May 28, 2009 | Maytag Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
375 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
