Question about Microwave Ovens
Our convection oven would not stop heating. Was set at 300 and was still heating past 600 . We shut her down.
    New Friend:
Needs new thermo state
Posted on Jan 17, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave convection heat shuts down
That could be several things, but to me the most likely is that your thermistor is caked with grease - somewhat shorted as opposed to open. By contrast, when the thermistor is open, the classic symptom is that the coolling fan runs more than it should. The other most likely possibilities include the damper motor or switch or control panel. You should be able to get any needed parts at Tritronics at http://www.wehaveparts.com You can find critical safety & disassembly info in the serice manual or at our Web site. We have the actual service manual for that model on our site at http://www.microwavedisplay.com/R930AKAW.pdf (if that URL fails try http://207.234.249.73/mwd/R930AKAW.pdf) Post back if you wish.
Posted on Dec 24, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
Posted on Nov 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: NNC2000P - Microwave does not work but convection works
An IGBT is an insulated gate bipolar transistor - sort of a hybird between a bipolar transistor and a MOSFET.
These are the final output driver transistors in the high-voltage inverter.
If it stops after 7 seconds, it still has a problem with the inverter.
It's likely a bad transistor, an electrolytic capacitor with an internal short or bad ESR or altered value, bad connection on the inverter board, a shorted diode or blown resistor, or a bad connection in the wiring.
Reputable service centers will have a repair warranty, but it may only be 30-90 days.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You should use a Panasonic-authorized service center so they'll have the service manual and (hopefully) experience and training to repair inverters.
In the US, you can find an authorized Panasonic servicer here.
This sounds like a non-US model. If so, visit panasonic.net, find your home country, then find the service / support links.
Posted on Feb 15, 2009
miket756
  • 2702 Answers
SOURCE: Microwave/convection oven in our fifth wheel will
looks like the timer brain has packed up on you,,
how old is it,, it may be cheeper to just replace the microwave as there not very pricy now,,there is very little inside them that you could fix your self, however,, putting your hand inside the back could kill you? so dont try it, play safe buy a new microwave insted
Posted on Oct 26, 2009
dmftrucker
  • 1922 Answers
SOURCE: Sylvania microwave convection oven overheats after
you need to remove the cover and after it operates and shuts down(CAREFULLY) feel the magnetron tube sides (BE EXTREMELY CAREFUL<HI_VOLTAGE ON TUBE FROM CAPACITOR) still, then if its not too warm there is a small temp sensor held by 2 screws on the side of the tube and they can go bad and shut off current to the tube,the tube will run warm, but should never run HOT,if its hot its defective
Posted on Oct 28, 2009
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
Set oven for cooking time, on setting 900 ,but only comes on for 4 seconds. I have tried the same on 600 it will run but does not heat
GO IN CONTACT WITH THE MAKER OF THE OVEN..AND DONT FORGET TO GIVE THEM THE MODEL NUMBER..AND IF STILL NEW UR RECEIPT AS IT WILL COVER UR WARENTY...
Oct 18, 2013 | Neff H5430 Convection Microwave Oven
Convection oven doesn't heat
Possible that the relay is faulty or there is fault on the control panel. It can also be related to problems on the thermocouple or sensors which can cut off prematurely the element.
Feb 11, 2013 | GE JES1290 Convection/Microwave Oven
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
Aug 17, 2017 | Sharp Microwave Ovens
Oct 28, 2009 | Sharp R-353 Microwave Oven
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
My kenomore Microwave has pwer and has stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
0ut
Dec 26, 2008 | Kenmore 63793 Convection / Microwave Oven
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
PROBLEM WITH SHARP R-1874TF CONVECTION OVEN
sometimes an over heat will shut down the oven for a little bit but lets look at other things
i dont believe the board to be bad but i do believe the heating element inside is fried or a wire got fried by heat
if you know how to use ohm tester i would check heating element and wireing first
then try to see if the timer gave out
Dec 06, 2008 | Sharp R-1874 Convection/Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
