Question about Sharp Sidekick LX Smartphone
Okay i had a flip phone and i just got the slide sidelick
I just put in the sims card and now its showing me a activation screen how do i get rid of that?
  • 3 Answers
Press the menu button and L at the same time
Posted on Mar 15, 2009
You have to call tmobile and star a new account
Posted on Feb 19, 2009
Iwant to change screen on phone
    • 1 Power off your cell phone completely by holding down the power button for four or five seconds. Turn the phone over and remove the back plate. Slide your fingernail underneath the battery and pop the battery out of the phone.
    • 2 Locate the SIM card if your mobile phone is a GSM style phone. Pull back the metal covering over the SIM card and then remove the card. Set it aside.
    • 3 pixel.gif Removing the RF grommet Find the plastic RF grommet at the bottom of the phone near where the battery was located. Grab the grommet with a pair of tweezers and remove it from the phone.
    • 4 pixel.gif Removing the bottom cover Insert the tweezers into the hole on the side of the phone opposite from where the RF grommet was located. Use the tweezers to pull up on the latch inside the hole to unlock the bottom plastic antenna cover. Lift the cover off of the phone and set it aside.
    • 5 pixel.gif Metal plate Pull out the screws along the edges of the phone using the Torx screwdriver. Take the metal plate off of the phone.
    • 6 Flip the phone over so that you can see the LCD screen. Slide the edge of a flat head screwdriver in between the seam of the plastic cover on the bottom of the phone. Wiggle the screwdriver up and down gently to unlock the catch underneath the plastic cover. Lift the entire plastic cover up and then off the phone.
    • 7 Find the latch on the side of the LCD screen and unlock it with the tweezers. Pull the screen slightly off of the phone and then disconnect the cable running from the screen to the phone. Lay the replacement screen back into the phone and attach the cable.
    • 8 Set the plastic cover back onto the phone and then flip it back over. Re-attach the metal plate and put the screws back in. Push the RF grommet back into place and then place the SIM card and battery back in the phone. Put the plastic cover on the back off the phone and then power it on to ensure the screen is working correctly.
Tips & Warnings
  • If your cell phone is a CDMA style phone, such as those provided by Verizon, it will not have a SIM card for you to remove.
  • Replacing the LCD screen on your mobile phone voids your warranty provided by the phone's manufacturer.
Feb 22, 2012 | Sony Ericsson Cell Phones
Presently my nokia 6700 is in off line mode showing on screed X. When I try to activate it in 'General' profile, it says 'insert sim card', however, idea sim card is already inserted in it....
Your phone is not detecting Sim Card .The problem might cause from the Sim Case or Sim Card Filter (IC) so contact nearest repairing shop or if you are a mobile tech try to make jumper.this is the best way that i can help you.thanks
Jul 01, 2011 | Nokia 6700 Slide Cell Phone
Samsung Star GT-S5230 Unlocked Phone with Full Touch Screen Quad-Band GSM Bluetooth, 3.2 MP Camera, have a card slot to put a sim card?
The sim card is inserted above the battery which is located on the back of the phone. The attached photo shows what you will see under the battery cover. First, turn the phone off. To remove the battery, start by removing the battery cover which is the back cover of the phone. Press on the back cover in the center next to the camera and pull the cover down towards the bottom of the phone. The cover should slide off. Slide the sim card, face down with the "notch" on the top right side of the sim up underneath the small metal receptacle designed for the sim card. If you do not see the receptacle, look for an etching of the sim card on the phone that is above and to the right of the sim card receptacle. wickerjk.jpg
Mar 02, 2011 | Samsung Star GT-S5233 Cell Phone
White screen of death?
Hello
The white screen of death is a flex problem.
The flex of a phone is what connects the screen to the board of the phone. it is found in most flip and slide phones.
When you flip and slide these type of phones after a while the flex gets weak and that causes the white screen you see.
The only solution is to have your flex changed,that will definitely solve the problem..
Goodluck
Feb 19, 2010 | Motorola Mobility Rival A455 Cell Phone
How do you replace the sim card on a nokia 2125?
The problem is that the 2125 is a CDMA phone and doesn't use a sim card. You can slide a sim card onto the inside of the metal casing that flips up but the phone lacks the components to reach the metal terminals on the sim card and thus read the sim card.
Nov 27, 2008 | Nokia 2125 Cellular Phone
I don't know how or what to open in the Nokia 2125 to change the sim card. We have removed the battery and flipped up the casing at the bottom of the battery cavity, but cannot see any other movable parts...
TMobile Sidekick Slide
FLIP THE PHONE OPEN AND PRESS AND HOLD THE MENU KEY WHILE PRESSING L ON YOUR KEYPAD THIS SHOULD BY PASS THAT SCREEN...ENJOY
Jul 09, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My Nokia 3250 in "offline" mode.
The problem is with the sim card. try to remove the sim, clean it with a dry cloth and put it back in. if the problem is not solved, take back the sim to your network provider and get a replacement, asuming the sim is damaged
Apr 12, 2008 | Nokia 3250 Cellular Phone
I HAVE PUT A NEW SIM CARD IN MY W810I AND ITS SAYING CONFIGURATION ERROR HOW CAN I REPAIR THIS OR GET RID OF THIS PROBLEM.
They don't tell you this when you get the new SIM card but you need to contact the phone service that you use your phone through and they will activate that card.
Feb 29, 2008 | Lands Phones
Inactive sim
u shuv it up ur ***!! thats wat i done it now works :D
Oct 30, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sharp Sidekick LX Smartphone Logo
110 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
