Question about Magic Chef Microwave Ovens
My magic chef microwave model #MCB1621W turn table (Motor) has stopped. Timer side all still works. Any ideas?
    Top Expert:
  • Magic Chef Master
  • 37,841 Answers
The motor under the turntable may have failed
Posted on Jan 17, 2013
  • Teresa Gushulak Jan 17, 2013
    Do you know if the motor can be tested? If I take off the motor, shld I be able to turn plastic turntable insert?
SOURCE: Magic Chef Microwave
problem solved
Posted on Jul 07, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Posted on Nov 27, 2008
  • 37 Answers
SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Posted on Aug 03, 2007
  • 686 Answers
SOURCE: Magic Chef Microwave Shutting Down Problem in RV
your micrwave may run fine at 110 but it draws more power than the generator is putting out when the magnetron kicks on which is the part that creates the microwave causing the food to heat up. In other words the amperage is too low for the microwave. Amperage is what matters not voltage.
Posted on Apr 12, 2009
SOURCE: My Frigidaire microwave stopped working while cooking food.
All lights are operational. Model number is FMV156DBC.
Posted on Aug 31, 2009
Turn table makes grinding noise
Hi, The motor that turns the turntable is bad...Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 25, 2011 | Magic Chef MCD1311ST Microwave Oven
Turn table does not move anymore.
Hi and welcome to FixYa, I am Kelly.
This is caused by a bad turn table motor winding or gear failure. You can go to this link:
http://mcappliance.com/partorder.aspx (Click on customer order) or call 888-775-0202 for the part.
Use the drop down menu and find your model number. The part will be Turntable Motor.
The linkabove should work. If not respond with your model number and I will look it up and find you more than one source for the part.
The motor is on the very bottom of the microwave. You can usually access it by removing the the glass turntable tray / plate and tipping the unit 90 deg. It is held in place with 2 mounting screws.
Thanks for choosing FixYa,
Kelly
Sep 12, 2011 | Magic Chef Microwave Ovens
Turn table stopped turning
This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The motor usually averages about $35 - $40, but the price also depends upon the model. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can purchase replacement parts at the any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back with your model number and let me know. I hope this helps you.
Jan 06, 2010 | Magic Chef MCD1110ST Microwave Oven
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
Magic Chef Microwave table does not turn , Model MCD990SC , Serial # 20600806 jojonew8@aol.com
not sure about this one. but if you remove the bottom, you may find the drive belt has broken. if this is the case just cut the end straight and super glue
Feb 19, 2009 | Magic Chef MCD1110ST Microwave Oven
Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
Jun 15, 2008 | Magic Chef MCD1311ST Microwave Oven
Defective microwave
I would definitely contact the manufacturer since most of them have a one year parts & labor warranty and they'll fix it free.
If you have your owner's manual, you can find their number. If not, please reply back with your brand and model number (or brand at least) so we can help you.
Sounds like a bad door switch or relay, and also possibly a bad magnetron or high voltage diode.
May 29, 2008 | Magic Chef MCB780W Microwave Oven
Turntable not turning
check control circuit, and related spares.
Oct 29, 2007 | Magic Chef MCD1311ST Microwave Oven
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Glass Tray table size?
Visit Magic Chef online and click the Cusomter Service link at the top: http://www.magicchef.com
Apr 03, 2007 | Magic Chef MCB780W Microwave Oven
Microwave Ovens Logo
122 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
