Question about Refrigerators
Where can I find a compressor relay?
Compressor tries to kick on and after a couple seconds just stops. Tried a rapid start and still couldn't get it going. Could it just be the relay is completely out? any suggestions?
Not an expert here but do you have an ohm tester you can check the relay then the compressor to make sure it's neither there's a lot of videos on how to do theses simple tests on you tube for a reference again not an expert but dealing with a similar problem myself
Posted on Jan 17, 2013
  • Daniel Zamora Jan 17, 2013
    I don't have one but I can probably get a hold of one today but thank you I'll try that.
hotuna
  • 288 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
The compressor is locked up. Basically it is stuck. You can pick up at the local appliance parts store a hard start relay, Home Depot ,Lowes, or or those guys wont have it. Its not too expensive and is worth trying because your only other option is you need to replace the compressor. The part is called a kick start or hard start, the guy at the parts store will know what you are talking about. It is simple to connect and has the wiring directions on it. Sometimes this is all it takes. I have been able to get a stuck compressor to go by placing a short 2x4 on it and whack it with a hammer a few times. This is only a temporary fix though, as it will eventually lock up again, but emergency situation this saved the food. If the fridge has a fan back there make sure it works too, it may have been the original cause. Good luck.
Posted on Dec 26, 2007
  • 236 Answers
SOURCE: Kenmore compressor cycles and does not cool
It sounds like you have a stuck compressor or bad start capacitor.
Stargazer
Posted on Mar 16, 2008
aborcass
  • 2651 Answers
SOURCE: buzzing noise from compressor start relay
sounds like your compressor is going bad, getting to hot , pull the unit from the wall and cleanall vents under and behind rear cover, make sure fan is running ot cool of the compressor, youll have 5 yr coverage on your compressor if needing repaired
Posted on Nov 11, 2008
SOURCE: Need schematic for refrig repair
i need to know how much pressure gauge on low and high for two side whirlpool refrige
Posted on Mar 12, 2009
  • 105 Answers
SOURCE: subzero 361rfd fridge compressor wont stay runnig
It sounds like you have either a bad relay or a bad compressor. The fact that you hear the compressor try to start indicates that the control is good and there is voltage to the compressor. I would suspect the strat winding of the compressor but a meter would need to be used to determine is this is true.
Posted on Apr 07, 2009
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
Compressor starts and runs for 15 seconds and stops. tested capacitor 15 mfd .i can hear the start relay open on start up and compressor stops . can it be the relay.
Its possible to be the relay, but if you have access to an amp meter I would see what the rating for your compressor is, it will be on a tag on the compressor, and see if its drawing too much or too little. That way you know if the compressor is bad. I've seen too many times on that particular brand techs change the relay just have the compressor fail two weeks later.
Apr 26, 2012 | Frigidaire FRS26H5AS Side by Side...
Kia rio 2002 air conditioning problems, Hi, currently my air conditioning just doesn't start at all, it was working properly and suddenly witout a warning it' just stopped working. It does not work...
If the AC compressor is kicking in and out then you are probably low on freon. If the Compressor isn't kicking in at all then the problem could be a fuse or relay in the Power distribution box or the fuse in the interior of the car. If the fuse and relays are good then the problem could be a bad clutch on the compressor or a bad compressor itself. If the compressor is kicking in and out then get a freon refill can from Walmart or an Auto parts store and add freon to the system until the compressor kicks in continuously.
Sep 28, 2011 | 2002 Kia Rio
I have a Maytag MSD2756GE* refrigerator that suddenly stopped cooling. The fan(s) work (freezer compartment as well as the one by the compressor). I replaced the adaptive defrost control board a year or...
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 25, 2011 | Maytag MSD2756G Side by Side Refrigerator
Compressor tries to kick on, but it humms for a few seconds and then kicks off.
this is a sign of a bad relay (starter) replacing the relay of the compressor might help if it does not help then you need anew compressor
Sep 06, 2011 | Refrigerators
My fridge stopped cooling properly today. For the last two days, I've been hearing a buzzing, about 15 seconds long, every 10 minutes or so. I didn't locate it until my frozen goods started...
Hi!
Leo Ponder
Aug 16, 2011 | Maytag MSD2756G Side by Side Refrigerator
Compressor cycles for about 20 seconds then I here a click and see a spark and compressor stops running doe's this every couple of minutes
does the compressor start when this is happening, if it does you have a start relay stuck and not allowing the start windings to drop out. Hope this helps.
Aug 12, 2011 | Refrigerators
The maytag skybox doesn't get cold anymore. we had it outside for a while (we didn't realize you couldn't have it outside) & it worked great all last summer. this spring, we realized it...
First you need to find out if the compressor is kicking on or not. If it isn't then it could be the starting capacitor (item 23), start relay (item 7) or the compressor itself. Since you had it outside I would suspect the capacitor or relay. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MBV1976AAB/3048/0168000/M0510224/00001
Does the skybox make noise (like your refrigerator starting a cycle)? If not, I would unplug it for a short while and let it set. Then when you plug it back up listen for noises on whether the compressor kicks on or not. If it doesn't then you can check the cap and relay board. Or have your compressor checked for operation and freon.
Jun 21, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
BARLEY COOLS COMPRESSOR WILL KICK ON AND RUN FOR 5 SECONDS AND KICK OFF EVERY COUPLE OF MIN THERE IS NOTHING ON THE COILS ANY IDEAS
Replace the compressor starter/overload relay. It's on or near the compressor. It will be making a click each time the compressor tries to start.
Nov 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Subzero 361rfd fridge compressor wont stay runnig
Apr 06, 2009 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
