Question about Whirlpool Washing Machines
Error code F50 - motor dosn't turn.
Whirlpool Cabrio Automatic Washer model # WTW6400SW2. All diagnostics, resistance, and continuity check o.k. Basket turns freely.Info from technician sheet packed with washer.
  • Whirlpool Master
  • 17,129 Answers
Please check for error codes: Whirlpool errors
Posted on Jan 18, 2013
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Cabrio Washer
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Posted on Sep 28, 2010
duby1990
  • 367 Answers
SOURCE: code f50
It has a faulty control board. sorry but this a bad part from the factory. There is class action lawsuit against whirlpool about it. Call and complain and then maybe they will pay to fix it.
Posted on Nov 19, 2008
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Cabrio Model WTW6400SW2
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
F 50 error code on whirlpool cabrio washer
Simple solution-- needs a new control pane. I just had to deal with the F50 code on a 4 year old Cabrio Wtw6200 model. Did diagnostics, it spun freely but took out the tub just to check, check all circuit plugs as suggested, etc,....At the point of deciding whether to junk it ($600 in 4 years) or gamble for a control board costing $155. and non-refundable if it didn't work. Went for the control panel (part #W10189966). took my husband and I about 25 minutes to replace, and it worked! Spins, no error codes, and even fixed the loud noise it used to have! Wish someone would have told us..... please don't waste your time on a repairman or other solutions...
Oct 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting the F50 code and I also got the SD code a couple of times. I followed the manuals directions and pressed pause/cancel and it still came back. We also unplugged the washer for about 30...
The "Sd" or Suds Detected error means that you used too much detergent. Reduce the amount of detergent that you use, and properly measure it.
When you receive the "F50" code, it means that the motor position sensor does not sense that the basket is moving. Remove any remaining packing material from the tub.
Hope this helps.. :)
Jun 09, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio wtw6200sw2 has F50 code and won't spin I can't seem to find out what the code means. Could it be the motor coupler or controller board?
The F50 code for the Whirlpool Cabrio is most commonly a Motor Control Board failure.
Motor Stalled
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
? Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
? If basket turns freely, see TEST #3, page 4 of the Diagnostics and Repair manual.
The Diagnostics and Repair manual can be downloaded as a PDF document file here:
http://www.mediafire.com/?np4yufblj33c0xm
DIAGNOSTIC TESTS
There are three diagnostic test modes available: Automatic, Manual and Console. These tests allow the factory or service personnel to test and verify all inputs to the machine/motor control. You may want to allow the automatic test cycle to complete prior to going into specific troubleshooting tests.
ACTIVATION OF AUTOMATIC DIAGNOSTIC TEST MODE
  1. Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on).
  2. Select any one button (except POWER, START, STOP and PAUSE/CANCEL) and follow the steps below, using the same button (remember the button):
  • Press/hold 3 seconds.
  • Release for 3 seconds.
  • If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
  • If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause.
  • If still unsuccessful, see Diagnostic: Unsuccessful Entry.
  1. The program then checks for saved fault codes:
? If there are no saved fault codes, all indicators on the console will momentarily turn off, then
turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
DIAGNOSTIC: Automatic
Performs a five-minute automatic test with water functions to check major washer functions (door can be open). Press the same button used in step 2 above to advance through automatic test steps.
NOTE: Basket must be floating in order to agitate.
Feb 01, 2011 | Whirlpool WTW6400SW Cabrio Washer
My Whirlpool Cabrio WTW6400SW2 has a F50 error. I
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^&
May 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
LOOK ON WIRLPOOL.COM AND LOOK UP CODES HIT THE CLEAR BUTTEN FOF35 SEC
Apr 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Model WTW6400SW2 Fault F50, Motor Control board shows no sign of any damage. Could mu problem be the RPS sensor? Motor simply wont turn
Aug 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%
Jul 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Code f50
Nov 18, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio code F50
I also had an F50 code on my Cabrio top load washer. Went through all the diagnostics, removed the tub, checked the motor, etc. After a lot of research, purchased a new control board (part #W10189966) and....it works even better than before....no more noise and spins perfectly. Very easy to install (3 screws and one bolt.) Please don't waste your time (like we did) checking all these other areas of the machine. The part was $155. (google it for best price new) and worth it if it will last another year or more...
Nov 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
105 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
