Question about Wicked Lasers Core Series Green Laser 5mW
Green laser wont work only dim red light inside
Only dim red light inside when i press button
I have a ml-2165w laser black printer, when try to print it tells me me disconnect and press on button, the light turns green then blicks then turns red. What do I do>
Dear
There may be some error related to fuser or LSU.
Pl. down load samsung easy printer manager from samsung site or it can found on the disk provided.
run it it show the error detail.
Thanks
Oct 06, 2014 | Samsung ml-2165w - laser printer -...
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Green light flashing 4 times,sencors lights on,press & hold wall button to open.others wont work
    The green light flashing 4 times is sending the code for " Safety reversing sensorsslightly misaligned (dim or flashing LED)". These are the sensors in the doorway. Tweak them a bit.
    Aug 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Samsung ml1640 laser red light blinking
    samsung ml1640 laser red and green light blinking continuously and printing not happening
    Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
    The Black prints faint on the left side of the page for our HP2605dn printer.
    Faded prints are possible due to following reasons.
    1. Fogged red mirrors inside the Laser box
    2. Alignment of the Laser Box
    3. Calibration Problem
    4. Cleaning Problem
    I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
    To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
    Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
    In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
    Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
    Jun 08, 2010 | HP LaserJet 2605DTN Color Printer
    LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
    4. Cleaning Problem
    May 17, 2010 | HP LaserJet 2605dn Printer
    My playstation2 wont turn on the red button is on. anyone have some feedback on this issure
    You need to press the red button to get the system to turn on. It should show a green light. There will be a blue light next to the green light if you also have a game inside.
    Feb 10, 2010 | Sony PlayStation 2 (PS2) Console
    I replaced the toner cartridge, but I am getting a blinking green ready light with a blinking red alarm light. will not print.
    This is a paper jam error. Try reloading the paer if you can not find any paper stuck inside the printer. Then press the start button.
    Dec 09, 2009 | Brother HL 1440 Laser Printer
    I've lost my manual and I can't get the laser pointer part to work.
    Press and hold Fn button and Laser button until the light turns red.
    Aug 30, 2009 | Honeywell PP4IN1 PP4IN1 4-in-1 Wireless...
    Blinking Green and Red light
    Misfeed:
    Put the paper back in properly, and then press the control panel button. The printer will start printing again.
    this is according to the website
    Oct 04, 2007 | Brother HL 1440 Laser Printer
    Wicked Lasers Core Series Green Laser 5mW Logo
    74 people viewed this question
    Top Wicked Lasers Electronics - Others Experts
    Are you a Wicked Lasers Electronics - Other Expert? Answer questions, earn points and help others
