Need the code for my car stereo as disconnected the battery, it's a four digit code for a rover 620 on a r-plate
    New Friend:
    Problem Solver:
  • 6 Answers
You will have to contact Rover and ask them. You will need your VIN number.
Posted on Jan 17, 2013
I have a seat ibiza 2007. I jump started the battery since it was flat. Now my radio doesnt work. Help
Does your radio offer a four digit input pass code?
Many stereos require this if they have suffered great voltage power loss or if they have been disconnected.
Nov 18, 2012 | Cars & Trucks
Wat is the stereo code for a standered landrover stereo p884 jvc reg
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft radio protection.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Land Rover service centre and get them to enter this code for you.
Jan 19, 2012 | Car Audio & Video
Mitsubishi Eclipse Spider Gt-S I cannot figure out how to get the fascia panel and face plate off of the radio to get to the numbers needed to retrieve the radio code. How do I take the panels OFF?
Hi
The stereo in the Eclipse can be removed with nothing more than a Phillips screwdriver
Disconnect the negative battery cable from your Eclipse's battery. Remove the two Phillips screws along the bottom of the radio/climate control trim panel. Lift up the bottom of the trim panel to unlock the lower retaining clips. Work your fingers around the sides of the panel to loosen the other clips and remove the panel. Remove the four Phillips screws holding the stereo in place. Slide the stereo out of the dashboard and disconnect the wiring harness and antenna cable from the back of the device.
Also check this link if it helps:-
http://www.ehow.com/how_5938157_remove-eclipse-car-radio.html
May 04, 2011 | Mitsubishi Car Audio & Video
I disconnected my battery to clean and now my stereo won't come on?
The radio has an anti-theft feature built into it. You need the four digit code to enter into it. Look within the owners manual packet you should find the code and entering instructions.
Feb 21, 2011 | 2001 Honda Accord
I have a 1996 land rover discovery, I just had a new battery put in and lost the radio code.I need the radio code and instructions on how to put it in the radio.
The folding pouch that came with the truck would have a card inside a plastic holder with the number on it. I do not know about pushing a button so many times and then on to the next number. All I do is enter the five digit code and bingo. I work on mine a lot and have to reset it every time I disconnect the battery. Check with the dealership or get online at a landrover forum;http://www.lrrforums.com/index.php?s=2520478ada19011f439696be3e4e31d3 and there are experts there who can help at no charge.
Aug 05, 2010 | 1996 Land Rover Discovery
How do i reset a stereo in a 1999 range rover
in most cars if your remove the battery for 15 minutes the car will reset, stereo aswell, before you do this i suggest checking if you have the stereo pin code as most cars have a pin code and when you reset it you will need the code, if you dont have it check your owners manual, if you do not have that bring details to your closest dealer, chassis number etc they will have it on their system.
Jun 21, 2010 | 1999 Land Rover Range Rover
I need the code to unlock the stereo in my land rover..?
I think its fairly standard across all Land Rovers. First of all you need a code. This was supplied on a credit card sized piece of card with the original vehicle. I'l assume its not to hand... Typically, you can source the code (which is specific to your serial number / radio) from a supplier such as this on eBay
http://cgi.ebay.com/Land-Rover-Radio-Code-Decode-Service-22Dc710-61B-61L-/380186172853?cmd=ViewItem&pt=UK_Audio_TV_Electronics_In_Car_Entertainment_GPS_In_Car_Audio_Players_PP&hash=item5884dc9db5
Code in hand, you are ready to enter it and unlock the radio.
You only actually need numbered button <1> and the two seek buttons that look like <| and >| .
When you turn the radio on, you should see it request <CODE>
Press preset button <1>. This should identify character 1 of the code.
Use one of the two tuning buttons (Seek up , or seek down - the ones with arrows going into lines) to move to the right number (0-9).
Press preset button <1> again to lock digit 1 and move onto code digit 2.
Repeat twiddling the upseek and downseek. Press button 1 etc .... until all four codes have been entered.
When you press <1> for the final time, if the code is correct, you'll get a two tone beep to confirm and the radio is unlocked.
If incorrect, you are progressively locked out (in doubling time periods).
Hope this helps.
May 15, 2010 | 1996 Land Rover Discovery
I have disconnected the battery to my MX5 and now when I try to use the stereo it just comes up with Err?
when the live is disconnected the stereo locks itself to unlock it you need the code which is usually a four digit number code look if its in the cars hand books if not a mazda main dealer will be able to get the code for you or i use a local radio code man than charges £10 so depending on how much it costs from a mazda dealer you may be as well buying a second hand cd player and putting that in
Oct 21, 2009 | 2002 Mazda Miata
Rover 400 series tape radio player
Hi if you radio is a blaupunkt type let me know the serila number bp************ and model number 7 64* **** **** you wil need to pop the radio out to get this information
Mark
Mar 07, 2008 | Car Audio & Video
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
