Question about Maytag Washing Machines
The machine agitates the load very slowly
The agitate wash chcle is very slow
  • Maytag Master
  • 17,130 Answers
Please check the belt , check the capacitor to the motor, you can couple a capacitor to the motor and see if the speed increases.If not there is fault in the motor drive or motor.
Posted on Jan 18, 2013
3 Suggested Answers
  • 1937 Answers
SOURCE: Slow agitator in Sears Kenmore 800 Series washing machine
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. .
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Jan 19, 2010
Testimonial: "I sincerely appreciate your responding and in such great detail too. I am going to try this. Thank you so very much. "
machinetech7
  • 1344 Answers
SOURCE: kenmore top load washer if agitating very slow
I would check the agitator dogs, as they are called. More than likely they need to be replaced.
http://www.partselect.com/PS388034-Whirlpool-80040-Agitator-Directional-Cogs.htm?inventory=388034&SourceCode=6
Posted on Jun 16, 2012
Kenmore washing machine agitates slow.
Hello & Welcome to FixYa
I don't think it has to do with any sort of belt instead it seems that something is stuck under agitator or the agitator needs replacement. You can view this video if you want to replace it yourself:
Please get back to me if you have any other questions.
Kevin
Jun 21, 2011 | Washing Machines
Kenmore Series 80 washer. Agitates too slow
check the dogs in the agitator take off the cap it should rachett if it turns free replace the dogs in the agitator
Jul 12, 2010 | Kenmore 24032\24036 Top Load Washer
My machine agitates slowly. Not sure what parts needs to be replaced. The machine is 11 years old, model # FWS445RFS2.
Hello,for your machine to agitates slowly, the problem is probably the agitator dogs or coupler is probably bad.
The agitator dogs are located inside the agitator and the coupler is the one that connects the motor to the agitator.
Thanks
Jun 09, 2010 | Washing Machines
Agitator runs at a very slow pace.
it sounds like the belt may be stretched not allowing it to agitate as it should
Jan 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
