Cars & Trucks Logo
Harrison Nixon Posted on Jan 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On my 2006 dodge stratus my cig lighter won't work
Stephen
Level 3:
Top Expert:
  • Cars & Trucks Master 21,873 Answers
  • Posted on Jan 17, 2013
 Stephen
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6207452
Points
67230
Normally this would be in your owners manual.
The power for the outlets may be on the same circuit with the horn.
On some models there is an accessory relay that handles the outlets.
There should be a 20amp fuse in the box in the engine compartment that feeds the circuit. You may have to check all of the 20amp fuses to find it.
4 Related Answers
Anonymous
  • 8 Answers
  • Posted on Jan 03, 2009
SOURCE: fuse for ciggarette lighter
there is a little fuse located behind the coins tray below the ac vent. when mine had the same problem the electrician had pulled out this tray and rplaced that fuse.
Anonymous
  • 4 Answers
  • Posted on May 06, 2009
SOURCE: cig lighter fuse blew. renewed but cig lighter and remote key not
you probably didnt change the right fuse and had another one blown at the same time you also could have a primary fuse under the hood that blew. once fixed dont use pump again. not same amps drawn
Anonymous
  • 104 Answers
  • Posted on Jun 03, 2009
SOURCE: 2006 Toyota Tacoma, power outlet/cig lighter not working
I am not sure about "fusible link", But the suggeation I can give you is to open dash or where the outlet is located and check the wires in the back of outlet with a light tester.
Anonymous
  • 1874 Answers
  • Posted on Sep 08, 2010
SOURCE: 2006 VW Jetta 2.5,
For 2006 VW Jetta 2.5, cigarette lighter fuse 20A (yellow) is placed in the fuse box on passenger's side. See picture below:
1helpful
2answers
My car lighter in my 1998 dodge stratus
look at the accessories fuse . It should be 15- 20 amps. The accessories fuse normally control the cig lighter, radio and anything else you run without the ignition being on
Abs light
Sounds like you shorted out the cig lighter which can also power other circuits. Have you checked the cig lighter fuse ?
1helpful
Need to know where to replace the cig lighter fuse
look in your fuse box under the driver side dash need your owners manual so you can look at a diagram
2helpful
How to replace 2006 dodge stratus cigarette lighter cylinder
The lighter base is held on with a threaded sleeve from the back. You would need to get access to the back of the socket to remove it.
You can look at a new part to see how the sleeve is attached.
2006 dodge stratus won't crank and cruise control won't light
Must not have been much of a mechanic. If the engine runs and sounds fine sometimes and other times it doesn't then it does not sound like a mechanical problem with the engine. Sounds more like a issue with either the ignition system or fuel system.
Horn, cig. lighters, and key remote won't work. Fuses good. Any idea what's wrong?
Ifg you`re a do it yourselfer, that sound electrical, it might be a relay issue, go fiverr and punch in wiring diagrams
If you need further help, reach me via phone at https://www.6ya.com/expert/reginald_d1f35dc049b0256a
I have a 2003 Dodge Startus RT and the lighter plug and the sound to the radio has stopped working... Could this be a fuse issue?
most likly, anything electrical that suddenly stops is MOST likly a fuse blown, shuld be a diagram on the back of the plate u take off to get to the fuses, find the CIG and RADIO and check them
2answers
Cig lighter works 4 cigs but wont charge satnav however much i twiddle about with it, help!!
Try checking the fuse inside the charger. Ths may be blown. Have you tried another charger in its place ex. cell phone or radar detector? If works for the cig lighter should charge.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
