Question about Acu-Rite Measuring Tools & Sensors
Acurite #02010-ccdi has 18 different weather forcast icons and only shows 3 in the manual.The unit is currently displaying icons that I am not sure what they mean. It would be helpful to see a list with meanings.
SOURCE: Nokia 6085 - unable to clear headset icon on display
i fixed this problem
The phone came with a headset. Plug the headset in and out a few times; it should reset the headset icon and phone can be used regularly again
Posted on Dec 27, 2008
nfraker
  • 10 Answers
SOURCE: Fallout 3 Freezing Problems???
Fallout 3 freezing is an unfortunately common problem. A lot of people have reported that clearing the game cache on your 360 will fix it, so that's what I would suggest you try first.
To do this:
  1. start up your 360, then take out the Fallout 3 game disc.
  2. Hold down the A button on the Player 1 controller
  3. Put Fallout 3 in your 360, then load the game
If this doesn't fix it, the next thing you could try is to clear the system cache. This will clear the entire cache for your 360, including the automatic updates (though downloaded content, save files, and user dats will be untouched).
To do this:
  1. Navigate to System > Memory
  2. Highlight the hard disk in the list and press Y
  3. Press X, X, LB, RB, X, X
If done right, you should see a message asking, "perform system maintenance?" Proceed with this, and it will clear all the cache data out and revert Fallout 3 back to version 1.0 (it should ask you to update once you load the game)
Hope this helps - I've had my share of frustration with Fallout 3 glitches.
-Nick F.
Posted on Mar 05, 2009
SOURCE: icon identification on text messages inbox
it means the message saved to your SIM card, not your phone.
Posted on May 10, 2009
  • 416 Answers
SOURCE: What does code P1405 mean ?
p1405 is a egr code (upstream hose off or pluged)
Posted on May 04, 2010
  • 17 Answers
SOURCE: My AcuRite 00992 wireless weather
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Posted on Oct 21, 2010
Geo button on acurite weather forecaster model 02010 won't work
My opinion would be do do a factory reset. If this does not work, warranty? Do you feel comfortable opening up the case? Could be a connection issue. (Do not do this if it voids the warranty.
The link below are the instructions for reset and other options:
https://www.acurite.com/media/manuals/02010_02014_02015-instructions.pdf
May 16, 2017 | Computers & Internet
My nextech wireless weather forcaster wont display out side temp. I have replaced the bats and held down the down arrow button
I dont have this unit but you might look for a reset button inside the battery compartment (or on the back, some times labeled).
Also, standard procedures are, remove batts. for a few minutes and follow the manuals instructions to start it up. Look for manual on internet. Also check for trouble shooting tips at manufactures web site.
You tested the "new" batteries, right? Long shot is leave batteries out over night to be sure unit is off. Try to find a reset button in manual or manufactures web site. Think about opening unit up with screw driver and look for reset. Did you follow instructions to select channel on both inside and outside units? My Weather Station has 3 chanels and I have to match them.
Nov 21, 2016 | Measuring Tools & Sensors
Acurite 436 shows temp at -18 consistently
You will need to return that or order another one. There is nothing you can do about recalibration or other maint. You could bring it inside to compare it with the temp on the inside unit.
Oct 22, 2016 | Measuring Tools & Sensors
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
Outdoor temperature reading shows -40 with wind chill -62. Outdoor temp is in fact +45.
We would recommend a hard reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac, and then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall battery into the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Mar 17, 2015 | Chaney Measuring Tools & Sensors
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
How do I change from Fahrenheit to celcius? Model # 00621cadia2
You can download the manual here http://www.acurite.com/kbase/00621_Weather_Station.html
Set the Time, Date & Units Press the "SET" button, located on the back of the display unit, to enter SET MODE. Once in set mode, the preference you are currently setting will blink on the display.
To adjust the currently selected (flashing) item, press and release the "up" or "down" buttons (press and HOLD to fast adjust).
To save your adjustments, press and release the "SET" button again to adjust the next preference. The preference set order is as follows:
TIME ZONE ( PST MST CST EST AST HAST AKST) DST (Daylight Saving Time ON or OFF)*
CLOCK HOUR
CLOCK MINUTE
CALENDAR MONTH
CALENDAR DATE
CALENDAR YEAR
TEMPERATURE SCALE ( ?F or ?C) BAROMETRIC PRESSURE SCALE (inHg or hPa)
*If you live in an area that observes DST, DST should be set to ON, even if it is not currently Daylight Saving Time.
You will automatically exit SET MODE if no buttons are pressed for 30 seconds. Enter setup mode at any time by pressing the "SET" button.
Jan 10, 2015 | Measuring Tools & Sensors
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
4. Reinstall the battery in the display unit.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
My AcuRite 00992 wireless weather station has suddenly quite displaying the outside humidity and dew point. Batteries are all new. I have lost my manual to troubleshoot this problem.
Aug 27, 2010 | Acu-Rite Adagio Clock Radio
Measuring Tools & Sensors Logo
64 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
