Question about Samsung DVD-VR375 DVD Recorder/VCR
Samsung VCR-DVD model 5650B manual please
Samsung VCR-DVD connected properly but unable to record or watch recorded programs> The technician did it once but I forgot how he did it. I need written instructions! Thank you
  • 3 Answers
SOURCE: dvd connection to cable
Connect cable on combo player cable in post to time warner cable box cable out post. and connect the combo player to TV with audio and video patch cords.
Posted on May 23, 2008
SOURCE: region free - Samsung DVD-VR375 DVD Recorder / VCR
I have managed to get a solution to this now. I have a region 4 as in Australia so depending on where you are you'll need to try the correct region. It worked for me first time. Point 4/ below my region code appeared in the top right corner for a couple of seconds not the top left! Once you've completed below turn the machine on again and stick in one of the dvds that would not work before.
Cheers Stewart
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Posted on Sep 19, 2008
quang123
  • 107 Answers
SOURCE: Samsung DVD-VR375 says "load" but tray for DVD/VCR won't open
I think you have problem in DVD deck assembly the owner manual won't help you if still under warranty bring back to Samsung if out of warranty you can buy the DVD deck from Samsung and replace by yourself
Let me know if you need part number for the DVD deck
Posted on Dec 09, 2008
SOURCE: Playing a recorded dvd from dvd-vr375 on another dvd player
If you are using DVD-R media, you can record in either V or VR mode.  What is confusing is that if you try to format the media, you only have the choice of VR mode -- and this mode is very well understood by other dvd players, some other records do understand it.  This mode has much better editing capability, but poor compatibility.  If you want compatibility, use the V mode.  The trick is that to do that, you don't format it!   V mode is the default and does not require formatting.  The owners manual says that, but too well hidden if you ask me
Posted on Mar 02, 2009
  • 13 Answers
SOURCE: I need a user's manual for Samsung DVD-R155.
you can go to samsung.com and on the top right corner there's a search box, go ahead and type in your model number and you are going to get 3 results. click on the 3rd link that says downloads and user manual. from there it will take you to the download center and you will see that you can download manual from a pdf file usinf adobe acrobat reader. or you can call samsung directly to have them send you one by mail.
Posted on Apr 17, 2009
I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
There you go..Your TV's video and sound is on the
DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
We recently connected to Direct TV...I want to transfer some old western TV Shows I recorded on my Direct TV DVR Recorder to VCR Tape. I was told by the people at Direct TV that I would need to contact you...
You can try this: Connect your DirecTv to VCR with Red/White/Yellow cables. Then the VCR to your TV with the same type of cables. Make sure the VCR is set to the video input, not the tuner. Turn your TV to the correct video input. Get the program ready on the DVR as if you were going to watch it. Press record on the VCR and then play on the DVR. At the end of the program, press stop on both. You may have a problem with the video recording properly. Some stations broadcast with copyright protection.
Apr 12, 2011 | Emerson Televison & Video
I have an RCA VCR model VR651HF that still works great. I can record shows without a problem as long as I'm not trying to watch a dvd. I recently bought a Sony dvd player model DVP SR200. I have my cable...
The sequence should go from the wall to the VCR then the VCR to the RF modulator then from the RF modulator to the TV and this should allow you to record a TV program and watch a DVD at the same time.
Feb 25, 2011 | RCA VR651HF VHS VCR
HOW DO RECORD AND WATCH THE TV AT THE SAME TIME. I HAVE A V5500 MODEL.
program DVD V5500 to record; use TV/VCR button at top, right of remote to change "operational mode" to TV (will display in DVD window) and use TV remote to change stations.
Jan 09, 2010 | Samsung DVD-V5500 DVD Player/VCR
Unable to record free-to-air television. by the way the television is samsung
Does recorder have Digital receiver - meaning can you watch tv through the dvd recorder? If it's a year or two old, it may no be able to pick up the new digital signals.
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
How to connect motorola cable box to samsung dvd/vcr model vr375 to a Westinghouse hdtv with 2 hdmi connections
The DVD-VR375 does not have an HDMI input. The connection should be:
• RED WHITE & YELLOW CABLE from your cable box (AV OUT) should connect to the DVD-VR375 (AV IN 1). Set the DVD-VR375 to AV 1 using the INPUT SEL. button.
• Next, connect an HDMI cable from the DVD-VR375 (HDMI OUT) to the TV (HDMI IN). Set the TV to the proper source.
This connection would allow the recorder to work as a pass through and will let you record TV programs as well as watch your cable channels.
Hope this helps!
Jul 06, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
Samsung DVD-VR375 DVD Recorder/VCR Logo
Jerry Greenberg
Jerry Greenberg
