Question about LG 26LG30 26 in. LCD TV
LG 26inch LCD tv
HI,
hope you can help me to fix the colour on my tv. I can get sound but it s in black and white and cant figure out how to have colour...
Thanks
Hi same problem as above with an LG 26LG30D bought today (25th January 2009) we have a "transact" set box cablke tv thing which we are getting the channels though but all is in black and white, dvds and VCR play in colour but not tv channels. all connections look right! help! please :)
Hhh
Posted on Jan 25, 2009
How do i get black n white to color
Where are the pictures coming from?
Off-air, cable, DVD, VTR, computer, etc?
Feb 13, 2015 | LG 32LD450 32 In. LCD HDTV
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
I have a LG tv and now i can´t get any colour???
Do a hard reset, there is a setting in the menu to put the set in monochrome mode, i think that is what has happened
Jan 07, 2018 | LG 37LE2R 37 in. LCD TV
LCD TV Wii only displays black and white - no colour no sound
You have to option in LCD Source In-Put.All LCD Have this In-Put
Com posit-Yellow/Red/White (AV)
In LCD Select AV Mode After That Connect Yellow /Red/White as per color pin given in your LCD.
Component-Green/Blue/Red
If you have Component in put in your LCD than select from source component mode for Red/Blue/Green.
Dec 26, 2009 | LG 32LG30 32 in. LCD HDTV
My DVD Video player is now only Black and White. I cant gert it to play in color What can i do? MODEL V271
check that the cables that go to the tv are in the right places and makesure that you are using NTSC ...NOT PAL and problem should be fixed :)
Jul 11, 2009 | LG V271 DVD Player/VCR
LG LCD Tv has sound but no picture only colour vertical lines. Can be fixed?
If your screen has a picture in the left corner with a small square with lines on it but still has sound...try this....
unplug your TV itself from the power source, then hold down the power button on the tv itself for 1 minute, then release.... Plug the tv back in and see if the issue is resolved. I just called LG customer support and a woman walked me through this process and it fixed the issue !!!! Hope this helps..
May 16, 2009 | Televison & Video
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
LG 26inch LCD tv
check cable connections. hd source with any cables other than hdmi or dvid will usually cause visual resets to very low resolution and to b an w sometimes. its part of digital rights management (drm).
good luck
mark
Nov 25, 2007 | LG 42LC2D 42 in. LCD HDTV
Set color on my LCD TV/monitor
i have a lg lcd.
and it colour scheme is very high
please give me suggestion for his colour setting
Oct 26, 2007 | Televison & Video
LG 26LG30 26 in. LCD TV Logo
285 people viewed this question
Computer Repairing
Computer Repairing
