Problem with my Iomega QuickProtect (model# GDHDU) is running, but the icon in the tray says it's "disabled". When I click the "enable" link it says: "This service cannot be started, either becaus
Is it muted? Look in Control Panel> Sounds or Device Manager> Sounds> look for the Sound device. Check the status, Disabled? Enabled? Driver status, working properly? If you haven't looked in the Tray Notication Area, right botton in taskbar and right click sound icon.
You can check or updates on the driver, also, check in the audio options,sometimes the audio device is disabled from there even after installing the driver. How to do so depends on your Operative System,but if you have the speaker icon on your tray you can right-click it and select the "playback devices" or "recording devices" depending on which is not working. Click on the device that seems to be disabled and click the "Properties" button. Somewhere in that window (usually in the lower area) there will be a drop-down menu that has the options of "use this device (enable)" or "Don't use this device (disabled)" pick the first to enable the device that is not working.
this should just be a matter od plugging in the drive, if recognised, right click on the drive icon and format to ntfs. If not recognised. Control Panel / Admin tools/ computer management / storage/ disc management. Locate the drive (which will appear unallocated) right mouse click on it, then new simple volume and format
Hi, Right click on the icon in the system tray and select open network connections, a new window will pop up, right click on the disabled network adapter and select enable. If the icon is not in the system tray go to the control panel, select network connections and enable the adapter. If it still won't enable you may have to enable the LAN (network adapter) in the BIOS. Please post back if you need anymore assistance.
