Question about poptropica.com
Pros and cons of poptropica
The good and bad things of poptropica
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
Tip
The 3 most popular fixes for the Xbox 360
These are free fixes I found on the internet and tried myself I have rated them as well with my recommendation:
The Towel Trick:
Pros
  • Fast and easy
  • Opening console is not required - does not void warranty
Cons
  • Might make things worse
  • Usually works for 2 weeks only
  • Not recommended to use repeatedly
Recommendation - Do it only if you are not technical and afraid to open the console, use warranty if still permitted.
The Heat Gun Solution:
Pros
  • If done right works for long (longer than the towel trick)
  • Simple to do
Cons
  • Opening console is required - Void Warranty
  • Usually works for a fews weeks only
Recommendation - Its involved voiding warranty and hard to make it a permanent solution, use only if you don't have a warranty.
The Eraser Trick:
Best solution here at Fixya:
The Eraser Trick
Pros
  • If done correctly works permanently
  • Very simple to do
  • Requires only a simple eraser
  • Can used repeatedly
Cons
  • Usually does not used right and not works permanently
  • Requires some technical knowledge
Recommendation - Read comments on the thread to know what to expect and do it only if you don't have your warranty.
Conclusion
- These fixes are great, but from my experience there is no stable fix for this problem since the Red Ring of Death will come back even if fixed by an expert. Therefore those fixes are good as any but also void the 3 years warranty. If you do have your warranty I recommend on using it.
on Nov 01, 2007 | Microsoft Xbox 360 Console
How to get to poptropica
Just type in Play Poptropica Free Online or look up Funbrain and there should be a add for poptropica.I did those things to get to poptropica.
Nov 08, 2014 | poptropica.com
How do you beat mistroy train on poptropica
i love that level! it depends what part u r at, but u collect all clues then talk to that guy in the diner cart i think. then when the train stops u have to keep jumping on top of things to get past the guards
Sep 29, 2012 | poptropica.com
On poptropica, SkullDuggery island,dragon cove,how do u get the stick to hit the big bell?
if you see the dragon statue thing in the water then you jump on the head and its on the tail u
under-water
Aug 13, 2012 | poptropica.com
Pros and Cons
Sansa e200 is increasingly not supported by the manufacturer, it may require you to manually switch between USB modes, and generally has a lot of problems. I can't think of any pros, actually.
The iPod has great support from the manufacturer and rarely has a problem that can't be solved. It is hard to use an iPod on Windows Media Player, but definitely not impossible. The probelm arises when you try to sync with Windows Media Player AND use iTunes.
I would definitely go with the iPod. Sansa sucks.
-Tha Mp3 Doctor
Dec 22, 2008 | SanDisk Sansa e250 MP3 Player
Fuel octane use
I use 87 just like the designers of the bike call for. pros=you'll go faster due to a lighter wallet cons=your bike may blow up
Nov 10, 2008 | 1989 Suzuki GSX-R 750 K
Pros & cons
Though the CLK may not carve up the turns,it does a decent job, but I felt it excelled in driving comfort over NJ **** roads. I do a lot of highway driving and prefer comfort plus I get up to 27mpg going nicley above 65mph.
May 14, 2008 | 2007 Mercedes-Benz CLK350 Convertible
Good & bad of this car
pros - Higher gas mileage, Interior quality, Access-door power windows, Sonar park assist, Body/suspension choices, Remote-start option. Cons - Curtain airbags not standard, Stability system not standard, Few innovations.
May 14, 2008 | 2007 Chevrolet Silverado 3500HD New Cars
poptropica.com Logo
67 people viewed this question
Top poptropica.com Computers & Internet Experts
k24674
Are you a poptropica.com Computer and Internet Expert? Answer questions, earn points and help others
