Question about Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728
Schlage lock will NOT turn. The problem is that this lock is on a shed and now I have no way into the shed without breaking a window or the door. I am using the Sclage key that came with the lock. How do I get the lock to work? Locksmiths are way too expensive. Cheaper to replace a window than hire a lock smith.
    Problem Solver:
  • 33 Answers
Try putting a thin oil on your key before you try to turn the lock . Also get a can of dry lube for locks & spray it into the lock
Posted on Jan 28, 2013
  • 10865 Answers
SOURCE: schlage B62 double sided lock
Hello. get a can of a penetrating lubricant called WD-40. Squirt a little into both key holes and let it sit for a couple of hours. Then insert the key and work it back and forth. If it is still frozen, repeat the treatment until you break it free. Joe
Posted on Oct 08, 2010
  • 16 Answers
SOURCE: Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Posted on Jun 21, 2010
Testimonial: "I will try your suggetion. Thank you."
  • 384 Answers
SOURCE: new schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
Posted on Jun 24, 2009
spencerfield
  • 31 Answers
SOURCE: Schlage deadbolt installed about a month ago. The
my guess is that during installation the inside lock cylinders were 1/2 or a full rotation more in one direction than the outside cylinders. remove it from the door, assemble it and try it without installing it. If it doesn;'t work, take it back. If it's old, oil it. if that doesn't work- toss it- you've spent an hour on a $15 item.
Posted on Oct 13, 2010
SOURCE: I have a two month
Hello My name is Lori and I work at Schlage Customer Service. If this is not a Schlage Key it may be possible that they did not cut the key to the correct code. Look on your key for the 5-digit key code and make sure the keys align up exactly - the keys also should be the same width. Also when you install this B362 you should install it with the katch extended and the keys out of the cylinder. Try some of these tips and if you still need help - please feel free to call us at Schlage Customer Service: 1-888-805-9837 Good Luck!
Posted on May 13, 2011
Our schlage lock with thumbturn on inside and keyed on outside. When unlock inside, knob turns freely as if it is really unlocked but if I close door, I get locked out. Please help
Be sure the outside knob is unlocked before closing the door.
Schlage locks do not lock the inside knob or lever. After releasing the turn button, also turn the inside lever or knob, then check the outside knob.
What model of lock is this?
Apr 09, 2014 | Locks & Locksmithing
Need to find code for Schlage keypad door lock but the sticker behind the plate is unreadable. I do have a key.
I don't believe that you can do without the programming code found on the sticker.Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Schlage FAQ: http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Instructions & Manuals: http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
I urge you to call and I hope that they can help you. Good luck!
Feb 15, 2012 | Schlage FE595VCAM716ACC Camelot Keypad...
Door will unlock without entering code
"Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial? "
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Feb 15, 2012 | Schlage BE365-PLY BE365PLY626 Satin...
Can't push one button to lock anymore
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the "dial". When disabled, you have to enter the user code, then turn the dial. So either way, you still have to turn the dial.
To enable/disable this feature, enter your Programming Code --press Schlage button--press 7
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
Complete installation & programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck-and please provide feedback if this helps!
Aug 12, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Videos for installing and programming can be found on this page:
Scroll down and find them under the heading Electronic Security-Keypad Deadbolt BE365
Aug 11, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
I can't find the code for my schlage keypad lock. Is there any way to reset my passcode without the original code for the lock
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
Feb 15, 2011 | Schlage Locks & Locksmithing
Hi does this lock auto lock like the one with a handel does?
To enable/disable this feature, enter your Programming Code--press the Schlage butt0n--Press 7.
Nov 23, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
Schlage B62 double sided lock - key will not turn both inside and outside and door is locked. inside, it is at 11:00 o'clock.
Oct 08, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728 Logo
496 people viewed this question
Top Schlage Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Schlage Measuring Tool and Sensor Expert? Answer questions, earn points and help others
