Question about Motorola Mobility OEM AURA Motherboard Flex Cable Ribbon
I need flex cable for motorola aura - Motorola Mobility OEM AURA Motherboard Flex Cable Ribbon
Hello how much the flex cable for moto aura
Motorola doesn't sell parts direct to consumers.
Mar 06, 2014 | Cell Phones
Razr v3xx broken flex cable
Is this one ? http://www.ownta.com/original-motorola-v3xx-cell-phone-small-flex-cable-with-ic.html
You'd better provide picture to them before you buy from ownta.com.
Good Luck !
Jan 06, 2010 | Motorola Mobility RAZR v3xx Cell Phone
No flip top light for Motorola flip top phone Model V276
Most likely a flex cable. The flex cable runs through the hinge. It is a high fail item. I used to replace 20 a week. Check to see if you can find a flex cable online. You will also need a small torx driver. I cant remember the size.
Jul 20, 2009 | Motorola Mobility V276 Cellular Phone
Prices
prices for Motorola Aura LINK
May 22, 2009 | Motorola Mobility Aura Cell Phone
Retrieving data, broken screen
hi
The Phone needs a new Keypad flex and most likely a left hinge pin. When the phone is open, the cable runs through the left side of the hinge. It is very common for the hinge pin to become chipped and put a small cut in the Flex Cable.
You can get the parts on ebay. search for motorola v3 keypad flex, and motorola v3 hinge, or knuckle.
thankyou.
May 04, 2009 | Cell Phones
Where to buy motorola mpx22o flex cable
you can purchse motorola mpx220 flex cable in delhi nehru place.
Jan 13, 2009 | Motorola Mobility MPx220
Motorla MPX220 Screen turning Red
where you got the flex cable from.....
Nov 03, 2008 | Motorola Mobility MPx220
Razr v3 flex cable connected but screen is still black
You can buy a new phone.....but I had the same exact problem with my motorola v3 phone. Every now and then both screens would work for a while and then turn completely black or sometimes white. Most of the time black. The keypads would light, I could make and receive phone calls, but I couldn't see anything on either screen. I moved all my contacts to the sim card and I got a new phone thru an upgrade with my company. But I was still determined to get the V3 to work again! I brought the phone to a few cell phone repairs shops and I was told that the connectors from the flex cable inside the phone sometimes get loose. Make sure they are tightly plugged in. If that doesn't help then the flex cable needs to be replaced. Some of these repair shops wanted up to $65.00 to replace the flex cable! I could replace the phone for much less than $65.00! So I decided to go to ebay and type in Motorola V3 Flex cable......hundreds of places came up that sell this flex cable. I found a place in my area and ordered one. It cost me $5.00 and I got it within 2 days! I looked online on how to install the flex cable and everything from how to disassemble the phone to installing the new flex cable and reassembling the phone was right there! I followed the instructions and I installed the new flex cable and the phone is as good as new!!! Both screens are working and I didn't loose any pictures or contacts from the phone!
All it cost me was $5.00 and about an hour of time! It even came with free shipping! Go to google and type in Motorola v3 black screen and look thru the solutions. Some of them will explain how to disassembe the phone and replace the flex cable with detailed pictures! You can buy the torque screw drivers at Home Depot or on ebay! Good Luck!
Jul 15, 2008 | Motorola Mobility RAZR V3
HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Dec 07, 2007 | Motorola Mobility RAZR V3
Motorola razr
YOU NEED TO FLASH A NEW FLEX VERSION. TRY TO TURN ON YOUR MOTOROLA BY PRESSING * # AND RED KEY AT THE SAME TIME TO GET IN BOOT LOADER VERSION. YOU ALSO NEED THE USB CABLE THAT CONNECTS MOTOROLA AND PC THEN DOWNLOAD THE FLASHBACKUP PROGRAM. ABOUT THE FLEX VESRION DOWNLOAD THE FILE FROM MOTOX SITE. BUT FIRST WRITE DOWN THE BOOTLOADER, THE FLEX VERSION ALREADY HAS AND THE S/W VERSION SO TO CHOOSE THE RIGHT FLEX.
Sep 03, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility OEM AURA Motherboard Flex Cable Ribbon Logo
85 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
