Question about Dryers
Dryer smells when running - Dryers
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
That couldbe your belt slipping
Posted on Jan 18, 2013
When drying clothes in my gas dryer, you can smell gas upon opening the door. If the dryer is not running, you do not smell a gas odor. Sometimes our clothes also have a gas smell.This just started a week...
Hi, from what you describe, it sounds like you may have incomplete combustion, which would leave a residual odor while burning. Check your vent, on the outside where the flap opens and the exhaust leaves the building. Anything blocking that vent may cause an air flow problem. If you have good air flow when the dryer is running, the problem is going to be at the gas valve/burner and may need a professional. In my town, the gas company will come out and check problems like this for no charge, they don't replace parts but are good at troubleshooting. Best of luck.
Jan 17, 2010 | Estate TGDS740JQ Gas Dryer
I have a Estate Whirlpool model#TGD5740. Smells like smoke when running. Still drys with heat and runs fine. What would cause this
You could have a build up of lent inside the dryer which might have ignited. Dryer should be dissasembled and cleaned.
Could be that your motor is over heating.
Depends on what type of smell your smelling;.If its the motor over heating, motor would have to be replaced.
Dec 27, 2009 | Estate EED4300SQ Dryer
There is a strong oil smell in the dryer
If you have recently painted or varnished inside your home the fumes in the air can create a hydrocarbon type smell in your dryer. This should stop as soon as the house is aired out.
Oct 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
I have a soured smell in my dryer when it not running
Does it appear that the smell is in the cabinet rather than the drum? I'm guessing that bugs or mice are living in there. There are no components in the dryer case that would smell except for a slight electrical odor. Remove the case and look around! Look for droppings around the back.
Aug 26, 2009 | Dryers
My dryer smells like smoke
just ry to run in on air dry for a while mayee wth dryersheets. charcoal and baking soda are also good at absorbing smell if you can find a way to implement them maybee baking sod box in dryer not running
Jul 09, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Gas Smell emitted from Gas Dryer only when dryer is running
check the gas line to burner, must be there if it only happening when unit is on
Mar 20, 2009 | Kenmore 74842 Gas Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryer smells hot
hi ,
run a load in fluff no heat and see if the smell develops again, if it does then I would suspect the motor or belt. generally most dryers are serviceable from the rear, the whole back panel usually, make sure you unplug it of course. make sure your not overloading your machine with clothes. It should never be more than half full ever. a slipping belt causes a burnout smell like when a car spins its tires at the races, if thats it you might need a new belt or your idler pulley may need to be bent a little so the belt runs tighter, study it
J
Jan 23, 2008 | Whirlpool LER5636P Electric Dryer
Stink Smell from Electric Clothes Dryer/Fuse Box
this should be quite easy to solve.remove the circuit breaker and sniff it. if it is the same smell you are getting when the dryer is running that is your problem.have an elecrtician check and replace with correct value.the dryer is most probably running on an overloaded circuit.
Jan 07, 2008 | Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
