I have a 1997 Ford Explorer (2dr), and was given an Alpine CDE 121 Head Unit to replace the factory radio. Need suggestions with the wiring.
Basically, the factory radio had two connections. One port was a smaller port that had (I think) 17 wires, and a larger, wider port that has (I think) 5 or 6 wires. The new head unit only has one small connection port with 16 wires (the connector that came with the head unit). I also have my vehicle's Wire Harnessing kit, which both of these are the larger, wider style port. So, I'm completely confused. I've seen wiring diagrams for the harnessing kit, the new head unit's included wires, and the Explorer's wires. They're all different color (Explorer opposed to the head unit), the explorer's smaller connection port won't fit in my head unit. And there is no large port input on the back of the new head unit. Do I have to cut and splice all the wires from my explorer and use the diagrams to wire them into my new head unit? I'm an idiot when it comes to wiring, just know the basics and trying to save $60 over going to Best Buy. Lol.
The original wires in the 95' thunderbirds are a pain, trying to figure out how to take out factory stereo and replace with aftermarket Sony cd player, have no clue because the wires don't match up, some do and they will load and unload discs but won't power up any suggestions...?!?
This generation of Vibe may have the upgraded audio system installed from the factory. In order to get the audio from an aftermarket radio to play through the factory amp, the factory remote turn-on lead must be located. If you are using an adapter harness, it may have the wire installed, just attach the blue/white stripe wire from the Alpine to the blue or blue/white stripe wire on the aftermarket harness adapter.
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet Car Radio Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: Orange/Blue Car Stereo Amp Trigger Wire: Blue (If Equipped) Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
well most commen tool is a phillips head screw driver (+) to remove components to get the old deck out you'll need a dash kit to mount the new radio in 15 buck from canadian tire or audio shop...
the easyest way to wire this up would be getting a harness to plug into the factory harness too get the color code and then u just make the connections red to red yellow to yellow makes it real simple that way... the other way is to get the hanes manual for your vehicle then find out what color each wire is then yu have to cut the factory harness wire up from the book takes alot longer but can be done its worth the 12-20 dollars to get the job done if you need more help ask
