Question about Canon PIXMA MX700 All-In-One InkJet Printer
How to fix canon mx 700 error 5800 - Canon PIXMA MX700 All-In-One InkJet Printer
SOURCE: Canon MX 308
How to reset canon MX 308 ??
Error Code 5800
Any Software to reseter this printer?
Posted on Dec 22, 2009
pineworks
  • 4041 Answers
SOURCE: CANON MX 700 CODE 5100 TRIED EVERYTHING
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
SOURCE: Error 5100 on my canon mx 310.
the 5100 is the carriage error and can be caused by 4 different sensors. First off the "Timing Strip" that passes through the back of the Carriage Assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use your flashlight to examine the timing strip as much as you can see. You really don't have much access to this strip unless you remove the covers,..and doing that is considerable work. The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage asm, and of course the main logic card. However, 99.6% of the time it is the Timing strip which is easitly contaminated with splattered ink.
Posted on Apr 02, 2010
SOURCE: canon mx 308 resetter
westink full
Posted on Apr 12, 2010
mace1mace
  • 1138 Answers
SOURCE: canon pixma mx 320 error 5800
there are two ways you can remove the error message from your printer..
the first is to reset the printer and the second is to replace the waste ink absorber. If the reset thing did not work for your then you'll be spending money to replace the absorber.
How to reset? follow these steps
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
Hope that solve the waste ink absorber in your printer..
Posted on Aug 04, 2010
What does printer error code 5800 mean?
This is an ink overuse error. It may read 5B00 and not 5800.
No real easy fix as far as I know but this video might help. Good luck! https://www.youtube.com/watch?v=0waX_GF-h7U
This video might help
Dec 02, 2015 | Canon PIXMA Office Equipment & Supplies
Canon pixma mx 700 won't scan showing error code 0x00000015
This is a windows or software error code,Uninstall the scanner/printer software and reinstall from the CD
If you have lost it you may download new drivers from here
http://support-au.canon.com.au/P/search?model=PIXMA%20MX700&filter=0&menu=Download
Aug 16, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Canon mx 700 printer gets the error code 5800.Please give me the solution.
Please remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels. Carry out all the maintenance Tasks like cleaning the print head, nozzles etc and check the ink cartridges by going to the properties of the printer.
The problem could be due to mechanical jamming. Could be fault in the transport of the paper in the rollers. There can be some jammed paper in the rollers or the mechanism.
Remove the covers to get access to the rollers and see if there is any obstruction or damage paper stuck up between the roller assembly. Remove the stuck paper.
Also, clean the other parts by blowing compressed air or with a soft moistened cloth.
Generally the solution lies in opening and closing the printer cover repeatedly till the code is not displayed
Jan 05, 2011 | Canon Office Equipment & Supplies
Phone is freezing at start up and cannot be turned off
hi,
your phone is having corrupted software,you have two option to fix that..first if you have this gadget you can do it it on your own...
1.) activated mx key dongle with ufs interface
2.)ufc cable
3.)5800 flash file ,MCU ,PPM ,CNT
here is the procedure,
A.) open mx key
B)connect the phone to mx key using ufc cable
C.)bus scan
D.)if the phone is now connected and you read the info
E.)put mcu ,ppm and cnt (warning ,the flash file must be higher than former version because 5800 is undowgradedable,to prevent more damage on its software...
F.)back up rpl and pm before fllashing (in mx key thick SERVICE <IMEI AND SECURITY ,ALL SECTION
G.)the phone is now safety for flashing ,then wait until its done...
if you have no gadget and tools that i mentioned above ,go to a nearest nokia care in your place ..i hope it will help you ,thanks for trusting fixya
Jun 19, 2010 | Nokia 5800 XpressMusic Smartphone
Canon pixma mx 320 error 5800
Jun 02, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Canon MX 308
Error Code 5800
Feb 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX700 All-In-One InkJet Printer Logo
73 people viewed this question
old marine
old marine
