Question about Frigidaire Refrigerators
FPES19TFLO water under veg. bins - Frigidaire Refrigerators
    New Friend:
  • 15 Answers
MOST LIKELY CLOGGED DRAIN LINE IN FREEZER
Posted on Jan 18, 2013
  • 958 Answers
SOURCE: water inside fridge
the water is coming from the top portion of the refrigerator section. the insulation between the freezer and the refrigerator is getting wet that is why the coldness of the freezer is transferring to the refrigerator trough the insulation foam. you can see droplets of water forming underneath the refrigerator section. sometimes you can see ice forming underneath also.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
  • 198 Answers
SOURCE: water under vegetable bins, no water in drip pan under refrigerat
If this is a top mounted freezer the drain under the evaporator in the freezer section is iced up. You will need to take the back panel in the freezer off, to get to the evap. Defrost the ice with boiling water, then a heat probe will need to be attached to the defrost heater and down through the drain hole, There is a kit for this procedure.part # 819043
Posted on Jan 27, 2009
farfield
  • 462 Answers
SOURCE: Leaks water inside, under the veg bins. I am
there is a tube on some of these model that goes through the back of the fridge and onto the bottom. It is usually up high (if not under the crisper s). If its close to the freezer compartment may have Ice blocking it. If its up high and behind a ceiling cover it could have dirt and gunk stopping it up. try a soda straw and push it in the open part of the hole. see if you get anything out. You say it freezes on the shelf in the fridge compartment (Im betting on Ice blocking the hole because this is way too cold for a refrigerator with veggies. Right?)
Warm water set inside fro a few minutes to hours with the door open or a hair dryer running in it for a few minutes may defrost it and solve the problem then it may come back if there is too much air from the freezer or the thermostat is keeping it running too long.
Hope this helps and if so please rate me accordingly and good luck
Posted on Mar 12, 2009
  • 47 Answers
SOURCE: Water leaks under veg bins..
This refrigerator look like mine (Picture).
Mine did the same thing. If it is the same then this is what I did.
Look under the there is a collection tray.
This tray collect the water.
At the bottom of the refrigerator (Inside where the water collect) is a cap.
The cap has cap would have holes or a slot that allow the little water to fall to the collection tray.
Mine has slots and was block up.
clean it out and that should do it.
The water should be able to fall to the tray at the bottom.
I do hope this help you.
Posted on Mar 29, 2009
aasc
  • 1606 Answers
SOURCE: GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW
Remove the food from the freezer . Remove the rear freezer panel , inside the freezer . At the base in the rear , use a hair dryer and defrost (you'll see a drain hole possibly in the middle of the drain ) . Defrost drain hole until hot water can be poured and go thru the hole . I use a small hose to blow thru the drain hole to remove any debris which could have accumulated inside the drain line .
Posted on Aug 02, 2009
I get .frozen water under my veg bin of my Samsung refrig.
The defrost water may not be draining and consequently refreezing. Check the drain in the bottom inside for blockage.
Mar 16, 2018 | Samsung Refrigerators
Ice build up under vegetable and fruit bins
Pull the bins out. Just above them is a channel with a hole in the middle. Push a drinking straw in the hole to clear the drain. The water will drain away instead of dripping under the veg bins.
May 04, 2017 | Refrigerators
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
Getting water in veg bins
Are the veg trays right under the drain hole? Check the hole is clear!
Apr 23, 2012 | Amana ATB2135HR Top Freezer Refrigerator
Not draining properly,water under veg. bins
Pull the veg. bin draws out and you'll see a hole that could be clogged with food or frozen water. First, clear away food if there is any. Then, pour boiling water into the drain and watch the bottom of the unit where it should be draining into a pan which will evaporate from the heat of the compressor.
Sep 27, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Do I wrap / cover produce or just place it in the bins? Wash first or not?
clean food goes in the frig . veg go in the veg bin. . if they are wraped they may mold and if left too long and they will dehydrate . so just use common sence . clean is good . do not keep too long . and some things will give off odors if not kept in something . hope this helped mm
Sep 24, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have water standing below the veg. trays, not sure where it is coming. How do I find the drain lines.
The water comes from the accumulated moisture. Just
clean the drain at the back of the veg tray. Get you veg. tray out so you will find the drain.
Sep 25, 2009 | Refrigerators
Water leaks under veg bins.. Cannot tell where it is coming from. Accumulates slowly
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
43 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
