Question about Sony Playstation 3 (PS3) Console
Ps3 wireless connection
Cannot register ps3 and have wireless internet whick wont connect to ip
  • 1 more comment
  • dturisk Jan 25, 2009
    i'm desperate
  • blackmatt198 Jan 28, 2009
    red light is flashing and wont link wit my ps3
  • brandon curry
    brandon curry May 11, 2010
    not very clear. on the register do you mean sign up for an account?
  • 83 Answers
I would suggest logging on to your home pc, checking the wireless settings then re-entering them into the PS3 internet settings, this happened to a familys PS3, but this solved it
Posted on Jan 25, 2009
I have wireless internet how do I get a ip address connect my ps3
The IP address is provided by the wireless router when you perform the connection process. You will need to locate your wireless network on the PS3, select it, and when prompted for the security key/code, enter it to gain a connection. Once the connection is established, the PS3 will have an IP address.
Oct 12, 2016 | Sony Playstation 3 (PS3) Console
Can not connect to internet with ps3 wireless wont connect says ip address has timed out
had that happen to mine too when i was signing up for a new psn account, make sure that there is nothing else running that it is connected to the internet or the ps3 doesnt connect
Apr 05, 2011 | Video Game Consoles & Games
I have a wireless internet connector for my xbox and i cant seem to get it to connect to xbox live. i can get it to read that there is a connection to my computer and the signal is stong but i it wont...
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Dec 23, 2010 | Belkin N150 Enhanced Wireless Router...
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont connect to wireless
Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Thanks
Sep 02, 2009 | Sony PlayStation® 3 (60 GB) Console
Cant get my ps3 to connect to internet through my wireless router
Assuming the media test works (So the cable/wireless connections are OK) then it's possible that you're out of available IP addresses in the router. It shouldn't be a problem (Most router configs allow for over 250 IP addresses), but it might only have limited leases.
Try switching everything off (Except for the router), restart the router and then try the PS3. That should rule out a problem with DHCP
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
No internet ?
When you connect your ps3 with a ethernet cord you need to restart your ps3 when its connected. If its wireless you may need to check your router settings.
Mar 05, 2008 | Sony Playstation 3 (PS3) Console
Unable to connect PS3 to my Secured WIreless Router
http://www.askdavetaylor.com/connect_to_the_internet_with_my_sony_psp.html
Jan 17, 2008 | Sony Playstation 3 (PS3) Console
PS3 connection error
Are you connecting through a router?. If so set all of your PS3 settings to easy. If your trying to connect directly to a dsl or cable modem, you might not get connectivity but may get an ip address, as some providers require that you register your MAC address with them to connect a particular device. If you have a router...say a wired one, and you connect any PC through it and get internet, you should be able to hook up the PS3 and put it on easy automatic settings for the connection and it should connect. However, if the router is set for a static ip address (no dhcp), it wont hand out all of the information to the Ps3.
Jan 05, 2008 | Sony Playstation 3 (PS3) Console
I can't connect to the internet
Make sure that when u go to internet connection settings to hit the scan icon and then it will show a list of wireless networks that are in range. Then click yours and click no for security. Hope this works
Dec 17, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
90 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
