How to get to the guts of maytag pav1000 performa
How to get to belt and clutch
  • Washing Mach... Master
  • 17,130 Answers
Check this link : Belt replacement
Posted on Jan 18, 2013
4 Suggested Answers
dutchman05
  • 487 Answers
SOURCE: MAYTAG PERFORMA PAV1000
Follow LINK
Posted on Jun 21, 2008
SOURCE: Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Posted on Feb 16, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Maytag PAV1000 that will not spin,
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 13, 2011
Can't find where the clutch goes on a Maytag Performa PAV 3300, is it in the transmission?
This washer is a single belt driven model that uses a thrust washer system to release the brake when the motor reverses. In wash mode a 200# spring locks the tub place while the transmission agitates the clothes. The pump cannot remove the water in this direction. In spin mode the the brake is released and the water gets pumped out. Here is a great pictorial that shows how to replace the kit along with a Maytag single belt washer service manual.
Oct 08, 2011 | Maytag PAV2300 Top Load Washer
It will not go into spin cycle, the belt is attached and it washes and rotates. What is the cause?
If your washer is not spinning you need to check this part.
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt(belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
Mar 28, 2010 | Maytag Performa PAV2200
Feb 15, 2010 | Maytag Performa PAV2200
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Need to change the belt on my Maytag Performa Dryer
The belt is a 341241, a pretty standard belt. To install it you must get the front panel off. Do this by using a putty knife: 549402b.jpgUse this hady DRYER BELT ROUTING guide
Mar 26, 2009 | Dryers
I need to find a new aerator & the guts
I had to go to Home Depot and stack a few adaptors together to get a proper fit. You will probably end up without an aerator but, you will be able to use the dishwasher.
Feb 16, 2009 | Maytag Performa PAV2200
Washer
THE SMELL IS THE BELT BURNING,YOU CAN REMOVE THE FRONT PANEL TO CHECK THE WATER PUMP,CLUTCH,BELT, AND TRANS,SOMETIMES THE BELT WEARS AND JUST STARTS SLIPPING.,LET MW KNOW-MIKE
Oct 19, 2008 | Maytag Performa PAV3200
How to instal new belt.
Remove the back panel, there you will find a tensioner, that will release the pulley.
Undo the belt routing and install the new one.
See here:
Maytag Dryer Belt Routing
belt routing for maytag performa ... -
Maytag gas dryer belt routing - FixYa
Sep 18, 2008 | Maytag Dryers
Maytag Performa loud gringding/clicking noise
Mlrescue,YES!
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jul 09, 2008 | Maytag Performa PAV2200
Washing Machines Logo
Top Washing Machines Experts
