Question about Canon Pixma MP500 All-In-One InkJet Printer
Paper jam help me plz every time i try to print or even turn on my printer it keeps comming up with this message..."paper output slot the paper is jammed. clear the paper and press [ok]." and ive tried everything to fix it. ive undone the back and i open the cover but theres no paper in it anywhere and i cant figure out what to do. is there a restart butten or something so it will be like i just bought it???
    Scholar:
  • 36 Answers
You can find the manual here http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 page 119 of the pdf gives you instructions how to remedy the situation. However since you state that there is no visible paper jam, it is probably a bad sensor. A google search yielded no results for replacement sensors. You will have a hard time finding any replacement parts for printers in the less than $100 catagory. Try this, I have located a sensor on a similar model multifunction cannon. Open the lid like you are changing out the ink. Right behind the rail that the ink heads move on just to the right of center you will see a black sensor flag. That flag is attached to a spring which brings it back. You should be able to see a small opening with tiny coiled spring next to the sensor flag. There is a LED that shines to a sensor. When the paper passes through the printer it hits the flag causing it to lift up and break the beam of light between the LED and the sensor. That is how your printer knows there is paper inside. Either it is jammed in the up position, or the spring fell off and the sensor flag is not reseting itself. if that doesn't work Do what they did in office space when it said paper jam when there is no paper jam. SMASH IT. and buy a new one. Hack
Posted on Jul 13, 2007
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
"Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Mar 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Mp830 shows paper output slot jam
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Jun 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Error - Paper Output Slot
Same problem with my mp600. Turns out I had a black twisty-tie in it. Must have fallen in from the top and ran through the printer as far as it could but got stuck on the way out. I pulled it out and presto!
Dec 24, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam cant fix it
Try for a re-set. See your manual How you do this can be a mystery because every make model it seems is different. If you have several button to press for various actions try this. Turn the printer off- press any two buttons together and whilst they are pressed switch on- holding the buttons down. Now I do not know how many buttons or combinations you can make on this particular machine so it will be a process of elimination. You could also get onto Canon Tech Support team. A useful site is also www.fixyourownprinter.com
Jul 12, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
213 people viewed this question
Clive
Clive
old marine
old marine
