Question about RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor
The charger doesn't do anything. I've charged the charger then hooked it up to the battery (pos on pos, neg on neg) then tried to start the car. No reaction whatever. Is there something else I
After I've charged the charger and the status light is green I hooked it up to the battery and pressed the yellow button and the light in the front came on. I then tried to start the car. Nothing happened. There was the same weak response that occurred before I used the charger. I then left the charger hooked up to the battery for 1/2 hour or so and tried aqain. No response. There is a little red button in the back of the charger. Am I supposed to push that in? Or is there something else I'm supposed to do to make the charger work?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
It's possible you may have a poor connection from your car to your car battery. Check to make sure both battery terminals are on your battery tight. Tighten them if necessary, then try again. If either one was loose, that should fix the problem. Then there may be nothing wrong with your battery charger.
Posted on Jan 27, 2013
2 Suggested Answers
archaeology
  • 662 Answers
SOURCE: My Duralast Gold Jump Starter does not take a
There is a battery inside which may need to be replaced. To check, run the compressor (it runs off
the battery) - if the compressor dies quickly, then the battery has failed to charge and would
need to be replaced. You may want to check your Warranty Management software (or
shoebox) to see if your Starter/Air Compressor is still under warranty - if so, replace it.
Duralast products are carried exclusively by AutoZone, Inc.
The Duralast web site: www.duralastparts.com is useless - it only shows automotive parts,
and I cannot find the product at www.autozone.com, so it seems that AutoZone fails to support this
product with replacement batteries or other replacement parts (or even an online Users manual).
Posted on Feb 21, 2011
How do you give a jump start to someone using a 2007 Dodge Charger?
The underhood connections can work by themselves...POS to POS, and NEG to NEG...sometimes dirty/weak connections do not allow the power to transfer fully from the underhood connections...if this is the case then you need to connect directly to the battery in trunk for full power charge...again POS to POS, and NEG to NEG...hope this helps
Jun 09, 2015 | 2007 Dodge Charger SE
How do you wire up 4 6 volt batteries in a 1976 kenworth. 12 volt lights 24 volt starter
When you go pos to neg from one battery to the next it increases voltage, pos to pos just increases amperage. You would want to wire 2 in series, just imagine stacking batteries in a flash light, pos from one to neg on next. Remaining pos and neg are 12v now. Run both remaining pos to starter and ground both negs. your pushing a lot of amps with the batteries and doing 12v, and your charging system is 12v. If you do another series from there, you have to regulate the voltage when the starter kicks in...you risk burning every light and electric component...just like running 12v in 6v system... You can also use 4 12v batteries and run all pos to pos and all neg to neg and have mega cranking amps...that is how all modern big trucks are set up. Your pushing around 7k cranking amps that way(1500 per battery)...plenty to start the healthiest cat... And don't have the worry of dual voltages or running in series. You really don't need 24v to start and unless you have a 24v alternator, these are your 2 options. Best bet if your not sure is to try with 12v...no risk of frying anything even on 24v system. 24v on 12v system is, on the other hand, a big risk. 43bf17ec-4e37-4a15-a147-d1e7a1377d9f.jpg
Jun 03, 2014 | Cars & Trucks
My acer tablet a110 wont charge over 50 percent
The battery pack is exhausted replace it.
Apr 05, 2017 | Cell Phones
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
Can I hook a battery charger to the jump start posts on a 2002 Chrysler Sebring, or do I have to connect it directly to the battery?
It is best if you remove the battery and charge it on its own, do not place the battery directly on the ground, sit it on a plastic surface or wood, then charge it.
If its starting to drain quickly, its a sign that your alternator is not charging anymore, have it checked to be sure.
Good luck.
Aug 23, 2011 | Chrysler Sebring Cars & Trucks
The battery on my 5230 wont charge up even tho its on the charger overnight ,ive charged it externally ,that is connecting the pos and neg from the charge lead diectly to the battery pos and neg this way...
just use a ziner diod neg leg of ziner sold to positive of charging connector and positive of ziner to battery connector plus ur problem will be solved
u can find ziner diod in old mobile like 1100 , 3300, 3310, 6600 etc.
Jun 06, 2011 | Nokia 5230 Cell Phone
How to hook up 2 new batteries
hook them up in parallel, pos to pos, neg to neg from one battery to another, then pos cable to battery prs and ground cable to neg battery
Jul 29, 2010 | Renault Fuego Cars & Trucks
My camera won't switch on. I thought it needed charging but the light on the charger unit only goes from solid red to flashing red. Whilst in the charging unit, I can view the pictures on the card and it...
The batteries when too dead won't charge, it is a known problem, some take a 9V battery and hook up to the battery, separated from the camera and charger, pos to pos neg to neg for a few seconds than try on the charger again, I've done this to a few of these Exilims with good success
Apr 24, 2010 | Casio EXILIM Card EX-S770 Digital Camera
Need to charge 12v car battery
If battery is out of the vehicle, connect positive lead to positive terminal and negative lead to negative terminal.
If battery is in the vehicle, the proper way to connect leads depends on if it's a negative-grounded or a positive-grounded vehicle.
Here is a link to the manual for this charger.
Click where it says "Get This manual" (it's free).
Scroll down to pages 4 and 5 and it give detailed instructions on the proper way to connect leads and a lot more. It's a good manual to keep for future use.
I hope this helps.
http://powertool.manualsonline.com/manuals/mfg/schumacher/se520ma_se5212a_se1275a.html
Sep 22, 2009 | Schumacher & Fast Charge Starter Charger
Fault light on vector battery charger flashing
Make sure that you have the pos and neg on right.
Mar 16, 2009 | 2005 Chevrolet Suburban
RoadPro Road Pro 12 Volt Dc Portable Battery Jump Starter & Air Compressor 12V Dc Portable Battery Jump Starter & 260 Psi Air Compressor Logo
139 people viewed this question
Top RoadPro Air Tools & Compressors Experts
Lawrence Oravetz
ray gallant
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Are you a RoadPro Air Tool and Compressor Expert? Answer questions, earn points and help others
