Turned on parental lock do not have password
Some how i turned on parental controls and now the tv asks me for a password to change the time or set the sleep timer but i did not set a password. i tried 0000 i tried unpluging the TV for a few hours but it still asks for the password
    New Friend:
    Problem Solver:
  • 8 Answers
Check tv manual for factory setting password
Posted on Jan 17, 2013
  • shellie349
    shellie349 Jan 17, 2013
    dont have the manual
  • jason Jan 18, 2013
    you might get the manual online
Have a vizio tv and an input locked messages appeared and turned the tv off . Now when you turn the tv on the tv shuts off. How can we fix this? We unplugged the tv and pressed the side . We plugged the...
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the side of the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV
6- Power the TV back on
Apr 27, 2011 | Vizio M370VT 37 in. LCD TV
Parental controls
try giving the reset ...........
Jun 29, 2008 | Sansui DTV2760 27" TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
I turned on tv and it had the parental lock on. I
When it asks you your code press 9 and QV at the same time . This only works with the mitsubishi remote.
Nov 14, 2009 | Mitsubishi WS-48313 48" Rear Projection...
Parental lock on cannot open it
Actually its, 'select' then '7444', and all that does is reset the password.
Press the SELECT button and enter the 4-digit number "7444" whenever the Parental Control display asks you for your password. The old password is deleted.
You will then be prompted to enter a new password, enter whatever number you want, something like 0000, or a number that is easy to remember. If you wish to turn it off, just set it to off and forget about passwords.
Notes
- When you play DVDs which do not have the Parental Control function, playback cannot be limited on this player.
- If you do not set a password, you cannot change the settings for playback limitation.
- Depending on the DVD, you may be asked to change the parental control level while playing the disc. In this case, enter your password, the change the level. When you stop playing the DVD, the playback limitation level returns to the original setting.
After changing DVD settings:
To save your changes, be sure to eject the DVD before pressing the RESET button or turning off the unit with the MAIN POWER switch. Please note that changes will not be saved if you reset or turn off the console without first ejecting the DVD.
Sony Playstation 2 manual, pg. 19
Aug 06, 2009 | Sony PlayStation 2 (PS2) Console
Parental control
Try this Hit "Menu" and go select the "Lock" sub-menu. It should ask you for a password. Initially the password for the US sets are set to 0 - 0 - 0 - 0.
If that does not work try 7 - 7 - 7 - 7. Once it accepts your password see if you have any locks enabled and turn them off.
Mar 05, 2009 | Akai Televison & Video
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
Mar 20, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
Dec 25, 2007 | Sony PlayStation 2 (PS2) Console
Televison & Video Logo
Top Televison & Video Experts
