Question about Pioneer DVR-530H-S DVD Player/HDD Recorder
Error Message "This signals TV system is different from the recorders setting" I get this message when trying to play from my digital camera, irrespective if I use analogue or digital inputs (S video or DV cables). It will record sound only. I have had this problem before, intermittantly, but it is now permanent. I have not changed any settings. When first plugging in cable, the picture flashes on my TV before the message appears. The picture looks fine. Any help would be much appreciated Thanks David
  • 9 more comments
  • david2301 Jan 27, 2009
    I have used this camera and DVD recorder together for quite some time. Generally it will play and record from camera without a problem. I am not aware of any changes to either's setup which would impact.
    Digital camera is Panasonic NV DA1
    I use a HD Plasma TV. If the TV is the source of the problem, does that mean I can play and record on my DVR if the TV is switched off and therefore not able to interfere?
    Thanks
    I have plugged my camera directly in to TV using S Cable and it plays fine. When I use S video cable through DVR, it will not play.
    Why wouldn't the analogue signal outputs from the camera work if the TV is set to analogue (They don't work)
  • david2301 Jan 28, 2009
    Which of the TV's many settings could be set to analogue? Why does the TV play direct from the camera if the TV setting is the problem
    Thanks
    I have no problems playing the camera direct through the TV, but it will not play through the Pioneer DVR. What particular setting in the DVR is likely to be incorrect, given above error message.
    Thanks
    Tried every other channel on the DVR, even though I know the correct one is called "DV"
    Not a channel problem
  • david2301 Jan 29, 2009
    Found it. The DVR setting needed to show NTsomething on PAL. When I changed to that it worked. Thanks to all for your help. I have no idea how the setting got changed.
    Thanks again
    David
    Pointed me in the right direction. Helped me deduct that problem was in DVR not TV
    Thanks to all
  • Pioneer Master
  • 19,396 Answers
You need to access both TV display menu, and DVD setting menu and set both tv and DVD to same resolution (eg. 780 dp).
If DVD does not have resolution settings, then set TV only to a lower resolution settings.
Posted on Jan 28, 2009
  • 11,896 Answers
Change the channels of the dvr
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    try hooking it up via rca jacks, or s-video, or hdmi. If none of these settings work for you and you have tried adjusting input settings on your system, then you inputs are fried out.
  • Nate Stansfield
    The DVR' has a setting for NT/ PAL which will change your aspect ratio. This could be your setting. check owners manual on how to change this settng
    President:
  • 1,214 Answers
You've got your video recorder video settings set to a resolution that the DVD player or TV can not interpret.
Posted on Jan 27, 2009
  • Mark Egan Jan 28, 2009
    Do you have your owners manual? There are a number of settings between the TV DVR, and your camera that are too numerous to detail here.
    The best start is to make sure you know where all settings are to be set to.
    Then step through upgrading the settings to improve the way the system works.
    Sadly, this is not all a plug and play system. You going to have to put some effort into understanding the way the various components talk to each other.
    Please clarify if the message is coming from the DVR, or is coming from the TV, and what brand/model the TV is. Also confirm the exact message given.
    The owner manual for the DVR does not indicate an error message that is anywhere near the wording that you have given.
    President:
  • 2,559 Answers
The video recorder learns a viewer's preferred programs and automatically record programs it expects a viewer to like.
A viewer also has the option to skip portions of a broadcast, such as for example commercials, You just need to change the setting in the setting menu.
Posted on Jan 25, 2009
  • Randy Hough
    Randy Hough Jan 25, 2009
    Sorry, I didn't realize you were using a digital camera,the error is due to the camera being set to digital and the tv to analog
  • 362 Answers
This error indicates that the signal from the camera is digital and the tv is set for analog.
Please refer to this link for further explanation.
http://www.electronics-manufacturers.com/info/video-equipment/digital-video-recorder-dvr.html
Let me know how it goes.
Lone99star
    Sergeant:
    Champion:
  • 435 Answers
Hi, We need some clarification. Are you trying to play from the digital camera?
This question is posted under Pioneer DVD recorder.
Please let us know the Make and model of the camera you are using.
Thanks,
Not receiving a TV signal through the DVD recorder and cannot record programs or watch TV through the DVD recorder
Firstly you must have a good connection from your antennae to the dvd recorder, secondly a good connection between recorder and tv
via scart lead or hdmi. Check these out before you do anything else.
Mar 21, 2014 | Panasonic Dmr-XW380 Dvd Recorder
My FujiFilm FinePix F47 fd has an error message that keeps saying 'Read Error' Help Please!!!
The Read Error message displayed on the Camera when accessing the images which was not recorded correctly. This may also happen when the Memory Stick is corrupted to record or read the files. Please check if the message is displaying when accessing all the images. If it happens with all the images, then it may be an issue with the Camera or the Memory Stick.
To check if the issue is with the Memory Stick, try using a different Memory Stick and check if the message displays.This may also happen when an attempt was made to play back the image or the movie that was not recorded on this camera.
Try to wipe the contact area on the Memory Card with a soft, dry cloth. It may be necessary to format the Memory Card (Format option is available in the Setup 2 Menu of the Camera). If the message still appears, service may be required.
Thanks for using FixYa.
Jan 21, 2011 | Fuji FinePix F47fd Digital Camera
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Jan 10, 2011 | Sony Cyber-shot DSC-W270 Digital Camera
Error message; has something to do with insertion of tape. Looks like triangle over straight line. beeps and blinks, will not play. Working when loaned to a "friend", returned in this condition...
Will it record on a new tape? Will it play a different tape? Have had a similar problem with a different camera. Think it had to do with the record mode / play back. A bit like standard play and long play - are there setting like that you could change?
Jun 26, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
I get an error message everytime I try to record
There is a switch on the VCR that says "tape/other". Change the switch from "other" to "tape" and you should no longer receive this message.
Mar 22, 2009 | ION Audio VCR 2 PC USB VHS Video to...
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
Files will not transfer to PC or play when attached to PC
Hi have you installed the correct software for your device
Dec 06, 2007 | Olympus WS-100 Digital Voice Recorder
Cannot play tape nor record on tape
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Pioneer DVR-530H-S DVD Player/HDD Recorder Logo
60 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
