Question about OKI C5100n Laser Printer
Rear picture of c5100
Rear picture of roller assembly
    New Friend:
    Problem Solver:
  • 6 Answers
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
Posted on Jan 28, 2013
The roller in the feeder has come out, I don't know how to put it back in
I am not sure as to which roller you are talking about but please find below the solution. !!!!DO RATE MY SOLUTION!!!Pickup roller replacement
  1. Tip the device over on its rear side, with the top of the device facing you.
  2. Rotate the bushings (callout 1) on each side of the roller upward. c02755446.gif
  3. Remove the left-side bushing by sliding the bushing to the left.
  4. Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and then lift the right end of the shaft.
  5. Slide the roller and shaft toward the right, and then lift the roller and shaft together out of the device. c02755447.gif -------------------------------------------------------------------------------------------------------------- This is for ADF (Automatic Document Feeder) on top of the printer.
    3. Press the round blue button while lifting the green lever. Rotate the green lever until it stops in the open position. The pickup roller assembly should remain on the surface.c00802892.gif
    4. Remove the assembly, and then wipe the assembly with a soft, dry, lint-free cloth.c00802893.gif
    5. Replace the assembly, with the largest roller down, in the upright holder, and then press until the assembly snaps into place.c00802894.gif
    6. Make sure that both sides of the assembly are secured by the blue hooks.c00802895.gif
    7. Lower the roller assembly, and then close the ADF cover.c00802896.gif NOTE: If jams continue in the ADF, contact a local HP-authorized service provider.
Jun 27, 2011 | HP LaserJet M3027x MFP Printer
Belt stops running although you can hear motor running. How do you replace front roller pulley?
Loosen off the rear roller adjustment bolts, 10 turns each side counterclockwise.
Remove the motor drive belt.
The front roller should now be removable. If you have difficulties, back off the rear roller adjustment bolts 3-4 turns further. Keep track of how many counterclockwise turns so you are able to readjust the belt after replacing the front roller pulley assembly.
Repeat the instructions in reverse once the front roller is in position.
Dec 16, 2010 | Epic View 550 Treadmill
When printing on my oki c5100 text or image - it prints fine but with a smudge/ghost of the image or text also on the paper. I know I need to order new toner - could this be why?
Open you printer and pull out the fuser assembly and look if the upper roller is fine because if it`s damaged it could lead to the double image.
Oct 20, 2010 | OKI C5100 Laser Printer
The upper roller that helps eject paper is broken. Need a new one.
hi,
please go to the following website to order your product online. you can check the part no with the description on side to shortlist the exact roller you are looking for. regards, venu.
The website in which the parts are available is
www.fastprinters.com/ProductDetails.asp?product_id=OKI-42194701
Please rate my solution and i believe its helpful.
Have a nice day.
Feb 14, 2010 | OKI C5100 Laser Printer
X215 paper pickup roller needs to be replaced
My experience is paper pickup rubber is old, shrunk and dried out. You can replace the entire roller assembly (including shaft) or the roller only or just the rubber, sponge tire on the roller.
The pickup roller with its square shaft and bearings are removed as an assembly. Remove
1) Cartridge
2) Paper Tray
3) Rear Cover
Four M3x10mm bright washerhead threading screws. Two of them are very low down in deep wells.
Carefully tug the cover rearward to remove it.
Note the parallel printer connector's bails when reinstalling this cover.
4) Right Side Cover (Optional)
Carefully tug the cover forcefully rearward to remove it.
5) Left Side Cover
Disconnect the speaker.
Gently tug the cover forcefully rearward to remove it.
6) Drivetrain Assembly
Mark the green ground wire location at one of the center screw.
Six M3x10mm bright washerhead threading screws.
One cable connection.
7) Gear Support Plate at Front Left
Three M3x10mm bright washerhead threading screws.
8) Electronics Pan
Two M3x10mm bright washerhead threading screws at the rear. NOTE the black ground wire at the left side screw.
Ten M3x10mm bright washerhead threading screws from underneath. NOTE that two of the screws are accessed through 10mm diameter holes in the pan.
Note the cable connections do not have to be disconnected and the electronics pan does not have to be completely removed.
9) Pickup Clutch
Pull it straight off. NOTE that it's indexed to only go on, one way. Note the other gears and their position (take a picture!)
10) Pickup Roller Assembly (w/Shaft)
One side bearing has a claw. Release the claw and the bearing can be slid toward the pickup roller, enabling removal of the entire pickup roller assembly.
Carefully remove the just old roller tire (or carefully just cut the old one lengthwise and discard). If you are careful, you can remove the entire pickup wheel by unlatching the small fasteners and removing the whole wheel, remove the old tire, reinstall a new tire and reassemble the entire assembly.
Dec 08, 2009 | Lexmark X215 MFP All-In-One Laser Printer
Our OKI C5100 is showing 171:Fatal error. What should we do?
The 171 Fatal error:
Upper Thermistor, State:Open
When an open circuit has been detected in the heat roller thermistor (low temperature)
Check the heater connector and the thermistor connector to make sure they are seated properly. If OK you probably need to replace the fuser.
Hope this helps.
Sep 03, 2009 | OKI C5100n Laser Printer
Double sided copying: Paper Jam at Rear Cover @ rollers;
Put your thumb on the lage black rubber roller and try to move it.
You might need hemostats to grab scraps.
Mar 14, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Bottom sliding rollers on side door volkswagon transporter
lift the mat over the doorstep there are two screw (bolts) at rear righ hand side,remove them to pull back channel guide. insert roller assembly put back screws and connect door.
Nov 13, 2008 | 1993 Volkswagen Eurovan
Oki C5100 feed fail - weak clutch/gearing
I have the exact same issue. Does anyone have a serice manual for this model so I can see just how big a job replacing the clutch is?
Thanks -- Steve
Mar 05, 2008 | OKI C5100n Laser Printer
OKI C5100n Laser Printer Logo
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
