Question about Frigidaire Washing Machines
I have a ghost, My Frigidaire washing machine will come on by itself with the controler off. If it is running a cycle it just keeps going even if you push the button off. unplugging it is the only way to get it to stop
  • Frigidaire Master
  • 17,130 Answers
Possible that the program controller is defective. You can remove and clean all the connections to the controller, check all the harness to the panel, if not the controller is a suspect.
Posted on Jan 18, 2013
SOURCE: beeping
Thanks! I found this online, which shows how to run tests on the washer to see what might be wrong, which helped, too. Now if i can just find a few muscly people to help me move the dryer from atop the washer.
http://forum.appliancepartspros.com/attachments/washer-repair/42d1194897506-error-code-01-wfk2401test.pdf
from this page:
http://forum.appliancepartspros.com/washer-repair/2385-error-code-01-a.html
Posted on Nov 26, 2007
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
Posted on Apr 23, 2008
SOURCE: E10 error on Frigidaire GLTF2940ES
I searched the internet for a list of error codes for the washing machine. The E10 error code indicates an interuption in water supply among other things. We checked the supply lines and found that the screen on the cold water line had been blocked by sediment ( we have well water,and just replaced the pump).
Posted on Nov 30, 2008
SOURCE: Frigidaire Front Loading Washer, ATF6000ES stuck on pause mode - HELP!
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Posted on Jan 10, 2009
  • 56 Answers
SOURCE: I have a whirlpool duet sport front load washer. It was running in the wash cycle. I had to cancel the cycle. Now the machine will power on, but when I put the start button it turns itself off. I've t
make sure you havent locked the console by accident it is in small print on the front right of the console other than that you will probably need a technician
Posted on May 30, 2009
Model number KUDS30IVBL0. When in the normal wash cycle the machine will go through the first wash cycle then drains. But the pump keeps running even after all the water has drained from the unit.
if you just let it go will pump shut off by itself after a few more minutes ?? or do you have to intervene as it will go that way all day long ?
Sep 02, 2015 | KitchenAid Dishwashers
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Frigidaire top load washer approx 6yrs old water keeps running into it won't stop and won't go into cycle water won't stop even by cuting the power had to shut off the valve
The problem is your water inlet valve has failed. It is stuck in an open position. Part # AP3267279 at www.appliancehelponline.com
cost is $37.87 easy to replace. Remove top cover to acess.
Mar 18, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Stops running after wash cycle emptys. the timer keeps running but the rinse and spin cycles do not engage.
Can you make rinse and spin occur by turning the control by hand to those positions? In any case, suspect the timer control itself, or maybe some of the wiring has come loose from the controller.
Oct 29, 2009 | GE WDSR2080D Top Load Washer
When i run the machine the breaker keeps going out. i tryed pluging it in deferent wall plug but same thing happenes. its been working fine till today.
Assuming there isn't a conflicting electrical load on the same circuit, there could either be a short somewhere in your washing machine or a problem with the washing machine transmission and/or motor. Since you already tried a different outlet (good move), it sounds like the washer itself. Try running the spin cycle alone with nothing in the washer and see what happens. It could just be the washer was overloaded at the time.
Apr 07, 2009 | Frigidaire Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Washing Machines Logo
16 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
