Question about Nostalgia Electrics Retro Series 0.9 CF Microwave Oven in Red
Cant get it to run
Cant get it to turn on no matter which button I push
Microwave keypad dont work
The problem is in the keypad control board, cost will run high making a new microwave oven attractive.
Apr 06, 2012 | Hotpoint Microwave Ovens
Thermador microwave doesn't turn on...you can set timer, push start but nothing happens
HI.When you turn ON your microwave,can you hear if motor is rotating?If you cant hear an ything from the motor..If you can check the terminal button of your oven.You can actually remove both sides of the oven and try to locate the terminal connection if it is engaged properly.Check also the motor.the motor might not be rotating or defective..Thank you for choosing FIXYA>>
Jul 20, 2011 | Thermador MBES Microwave Oven
I have a Shapr Microwave Convection model R-8880(W) T which is flashing after being stored for 3 months. It won't work, the timing light just keeps flashing on andoff 88-888. Does it have a reset...
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Kelly
Dec 26, 2010 | Sharp Microwave Ovens
Whenever I went to warm up my tea this morning, my microwave says, "LOCKED" regardless of which button I push. I can't get it to work no matter what single button I push or combination of buttons. HELP
It sounds like you may have accidentally set the child safety lock. Some ovens have this feature as a safety device to prevent children from manipulating the controls. If the model number you have this listed under is correct, all you have to do is press and hold the ENTER/START button for 4 seconds and the lock will clear. If the model number is not correct, post back with your correct information, or refer to your owner's manual under the "Operating Instructions" section.
If you have questions, or require additional assistance, please let me know. I hope you findthis helpful.
Aug 21, 2009 | Maytag MMV4205 Microwave Oven
Cant figure out how to set clock
try this first,
1 push button= clock
2 set the #s of the time
3 repush the clock button
Jun 24, 2009 | Emerson MW8168B Microwave Oven
Microwave turns itself off after a couple of seconds
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Micrwave does not heat, and turns off by itself before time
Unplug the Microwave and remove the outer cabinet. Inside the cabinet will be a thermal insulated fuse, looks like the old buss fuses for early model cars but white. Replace that with the correct fuse which can be found at Lowes or Home depot and see if that solves the problem. Be careful not to touch any capacitors if they are in there.
Mar 14, 2008 | Panasonic NN-H664 Microwave Oven
Turning off before finishing time time cycle
I have just had this problem where the oven will only run for 5 seconds and then turns off model #NNS561. Cant find any solution.
Jan 19, 2008 | Panasonic NN-S950BA Microwave Oven
Unit does not turn off
open the control push boton and clean it one of the boton stoct.
Sep 19, 2007 | Panasonic NN-S254WF Microwave Oven
Nostalgia Electrics Retro Series 0.9 CF Microwave Oven in Red Logo
14 people viewed this question
Top Nostalgia Electrics Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Nostalgia Electrics Microwave Oven Expert? Answer questions, earn points and help others
