Question about Exercise & Fitness
TROJAN RUN X drive belt motor will not switch on ?
The whole unit powers uo perfectly, but on pushing "START" the 5 sec countdown completes and the unit powers off ? The 3,5 HP DC motor does not engage at all I alternatively get the L5 or E4 ERROR CODE ?? WITH A MULTIMETER on the DC MOTOR input leads I get a reading of 10 - 16 V DC ? (which would indicate it is in communication with the upper control panel ? PCB ? But when the START BUTTON is pressed the voltage drops to ZERO and the drive motor does not move at all Incline feature etc still work The magnetic speed sensor on the drive wheel is clean, dry and correctly positioned as is the pickup track on the pulley This has happened suddenly, previously the motor was a bit sluggish to start sometimes but functioned correctly at varying speeds onceb it started ? In am presuming I have a switching or electrical contact problem somewhere between the 220 V AC POWER supply and the 220 VAC - 229 V DC Transformer that is preventing the DC POWER reaching the main drive motor ? (and presuming the 220 DC motor is working OK, it spins quite freely by hand Can anyone point me in the right direction or have had this problem before , I am semi hemiparesis (left side paralysed after a series of strokes and I urgently need to get this working for my rehab. I will probably have to supervise this as I have very limited mobilty and am unable to get down on my knees etc Any all suggestions much appreciated Is there a site where I can download an instruction manual for this machine Thanks John H my email yachtshelaa@ yahoo.co.uk
  • 33 Answers
SOURCE: Belt won't turn.
HI, please replace the control board
Posted on Oct 02, 2009
SOURCE: Proform 730i powers on but will not move when I input speed.
I have the same treadmill with the same problem statement. Here is how I fixed it:....Open the lower shroud that covers the motor. You must remove 4 or 5 screws. Taped to the inside of the shroud should be a document with a calibration procedure on one side and electrical specifications on the other. It will tell you how to run the calibrations. You need to hold the stop button and the + speed button as you insert the safety key. This will put you into calibration mode. My treadmill started working again after I ran the incline calibration routine. Hope this helps.
Posted on Oct 31, 2009
outfield502
  • 79 Answers
SOURCE: my treadmill motor starts exactly
that a qualified technician check the motor controller board the mosfet (IRF250N.) or diodes
Posted on Sep 08, 2010
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
ercupa190
  • 12223 Answers
SOURCE: Hello, I have an ENERGETICS PR 2.8 Power run
1) This error code has 2 options
a) Elevation Motor: a) lube the gear and shaft b) adjust the potentiomenter c) test the motor see my personal tips for help.
2) Display board: a) adjust the reed swithc , see the diagram attached, clean, tight the wires connector very well.
After you did the adjustment RUN the software calibration for diagnose and troubleshooting.
God bless you
Posted on May 12, 2012
Testimonial: "I cannot find my manual on the site :-( I have the original manual but this type of information is not displayed. I am not sure how to adjust the 'elevation motor' ? I still cannot see the magnet/reed switch on either the motor pulley or the front roller - are you sure all treadmills have these and might it not be built into the actual motor? The link to your "personal tips" does not take me to the correct page?"
Brush Cleaning did not clear the (L / R) HPR> 45F (7C) AFTER 1 HR fault on my Taylor Model C723 soft serve ice cream freezer.
Certain conditions must be met. The machine needs to be empty. The freezer door must be off the machine. The power switch must be off. Once the machine is off, a 5 minute countdown will show. It will also show 4 temperature readings. All 4 of them must be above 60 degrees F. before the countdown will start. Once the counter reaches zero, the Brush Clean Cycle will be reset along with any temperature vs. time error codes. If at any time, one of the temp readings drop below 60 degrees F. before the end of the 5 minute countdown, the countdown will reset to 5 minutes and the machine will not reset. Generally, the freezing cylinders take longer to come to temperature. Even when you run warm water through it first, there is sometimes enough residual cold to bring the temperature back below 60. A successful Brush clean Cycle will display "Power Switch Off---Unit Cleaned" and the 2 digit green display under the main display will reset to 00. if this happens and you turn the machine back on and you are hit with the same message then you may have an issue with one of your boards.
Aug 02, 2017 | Taylor Ice Cream Makers
Have lid off there is power as got a small shock. LIght wont go on seems like no power at all
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Feb 01, 2016 | Zanussi Dryers
I need a diagram for a 2001 VW Cabrio relay. I thought number 6 was for the blinkers/hazards but it's not and its empty. 413 is in there and blinkers and hazards just stopped one day. I don't know if I...
A2Resource
a great vw resource site
Relays:
Num.Relay Arrangement and Pinout (with control number stamped on relay)
1A/C Relay (13 or 140)
1A/C Switch
2Radiator Cooling Fan
3Fan Switch High Speed
4Battery, Fuse 23
5A/C Clutch (via pressure and temperature switches)
6Main Fusebox Battery Power, Fuse 19
7Main Fusebox Ground
8Fresh Air Fan
2Rear Wiper Relay (72)
1Main Fusebox Ground
2Main Fusebox Run Power, Fuse 4
3Rear Wiper Motor
4Wipe/Wash Signal from Switch
3Digifant Control Unit (30 or 32), Motronic OBD1 Control Unit (109)
2Tachometer
3Main Fusebox Start/Run Power
4Main Fusebox Battery Power
5To ECU (relay ) (1990 G60, ABA/VR6 OBD1 only)
6To ECU and Engine Electronics
4Load Reduction Relay (18)
1From Ignition Switch Run Power
2To Main Fuse Box Run Power
3Main Fusebox Battery Power
4Main Fusebox Ground
5Low Coolant Level Control Unit (43)
1Main Fusebox Start/Run Power
2Low Coolant Level Sensor
3Coolant Temperature Sensor, Gauge
6Flashers (21)
2Flasher Output
3Flasher Input/Power
4X/6 (Trailer Light)
7Headlight Washer (33)
1Main Fusebox Ground (B/4 to C/3 to Ground)
2Headlight Washer Pump
3Headlight Switch Pin 56 (headlights) (B3 to D4 to light power)
4Main Fusebox Battery Power (B/5 to Y/2)
5Windshield Washer Pump (B/1 to B/2 to washer pump power)
8Wash/Wipe/Intermittent Relay (19 for standard relay, 99 for variable intermittent module)
2Intermittent Switch
3Main Fusebox Run Power, Fuse 5
4Park/Low Signal (ground when parked, positive when on low speed)
5Wiper Motor Low Speed Output
6Wash Switch (positive for front wash)
9Seat Belt Warning Control Unit (4 or 29)
2Seat Belt Switch
3Door Switch
4Seatbelt Light
5"Key In" Power from Ignition Switch
6Main Fusebox Start/Run Power
7Automatic Shoulder Belt Controller
9Radio/Lights Buzzer (36)
1Main Fusebox Ground (not used)
2A1/4 (Left Parking Lights)
3Vehicle Speed Sensor
4Seatbelt Light (not used)
6Main Fusebox Start/Run Power (not used)
7A2/2 (Right Parking Lights)
10Fog Light Relay (110 for fog lights with low beam headlights only, 53 for parking light/high beam fog lights)
1Parking Light Power
2Headlight Switch Headlight Power (Low/High)
3Fog Light Switch Power, Fuse 10
5Main Fusebox Ground
6Low Beam Headlight Power
11Horn (53)
2To Horns
3Main Fusebox Ground
4From Horn Button
12Fuel Pump Relay (80, 67 or 167)
1Main Fusebox Starter Power (not used)
2Main Fusebox Start/Run Power
3To ECU (Fuel Pump )
4To Fuse 18, Fuel Pump, Oxygen Sensor Heater
5G2/6 (not used)
6Main Fusebox Battery Power From 30B
7G2/7, T1 (not used)
8Main Fusebox Ground (not used)
9M/4, U1/8, G2/5 (not used)
12Glow Plug Relay (102 or 104)
3Engine Temp Sender (preheat)
4Glow Plugs (Z1)To Fuse 18 (not used)
5G2/6 (not used)
9Water Separator, Glow Plug Light
remember to check out the website below for more help
http://www.xjamiex.com/mk2resource/electrical/CE2.html
Dec 30, 2014 | Cars & Trucks
We have a fan 60 minute push button timer we purchased and installed with a 3-wire system. WE need to purchase another one but they all have 4 wires now. Where can we purchase a 3-wire one.
It sounds like you have mechanical push-button type timer.
I need more information to avoid guessing which timer is best for your situation.
I'm not sure what a 3-wire system is?
Add a comment
1) How many switches control same fan
2) What color wires inside box.
Is this
3) low-horsepower bathroom fan?
4) other fan, for example: higher horsepower attic fan, 3/4 horsepower industrial kitchen fan, or 1-horsepower whole house fan?
5) Is this your home or is fan for continual commercial use?
6) Is this a countdown timer that turns fan OFF automatically after 60 minutes?
7) Or what kind of timer are you looking for.
Open following link for list of home-use countdown timers and horsepower ratings of countdown timers.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Spring-wound timers do not require extra Neutral wire, and can control 1 HP whole-house fan.
The push-button timers each require Neutral wire to run electronics inside timer, and they range from 1/6 HP to 3/4 HP which will work for any bathroom fan.
If you cannot give required information for more free help, then request fixya interactive answer and pay fixya expert to ask same questions while expert supplies you with immediate information.
Apr 06, 2011 | Woods 60 Minute Decorator Wall Timer...
Wiring. # 2 is neutral # 3 is hot in. # 1 will be hot out when 6&7close
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
You are correct.
#3 is Neutral from breaker
#2 is 120Volt Hot from breaker
#1 is Black wire to load
#6 and #7 are activated with a push button
When activation takes place, the timer turns on power to the load
The timer begins a countdown
The load cannot exceed 1 amp
Power to the load remains ON until the timer countdown is finished
If you have ordinary switch instead of a push button, then you turn on the switch, and timer countdown begins after you turn the switch off.
Oct 29, 2010 | Dayton Audio Dayton 6a857 Solid State...
My Whirlpool WED8300SW stop turning yesterday. Clothes got really hot. I ran the diagnostic and got the F26 error code (motor drive failure). It is just 1 year old (about 15 months actually). I am fairly...
The standard warranty on appliances is two years, contact Whirpool at (866) 698-2538 to check warranty status.
Regarding the motor, the motor is tested by energizing it directly, and reading volts from MCU (motor control unit) or timer control board.
Here diagrams and parts for your model.
Call Whirpool first.
Aug 04, 2009 | Whirlpool WED8300S Dryer
Loading stays forever
First you do is to unplug the cord of your DVD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the DVD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the DVD unit and unplug the unit again to avoid electric shock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the DVD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Jul 07, 2009 | JVC DR-DX5 DVD/HDD Recorder
Whole house Fan Stops running after 10 minutes
Tightened the belt, lubed the fan and it seemed to work intermitantly.... Still ahving ussues..
aaaarg!
Jun 20, 2009 | Ventamatic Direct Drive Whole House Fan...
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Exercise & Fitness Logo
105 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
