Question about GE WVSR1060A Top Load Washer
We have an LG Direct Drive WM2101HW front loader washing machine. It is three years old. It is making a horrible grinding and squeaking noise once on the spin cycle. Not sure what is causing it and need help!!! The warranty is no longer good, but we do have the 10 year motor warranty.
  • 1 more comment
  • Crystal Jan 17, 2013
    I do keep it cleaned out per the suggestion of the LG manual. We actually just did a tub clean recently.
  • Crystal Jan 20, 2013
    Does not resemble an airplane. Thanks.
  • Crystal Jan 23, 2013
    We found that the rotor assembly was bad. The plastic teeth were shredded. We were able to replace it since everything else looked fine for $80. Now the drum spins during the spin cycle and does not make that grinding noise. Praying this doesn't happen again, but if it does, we'll be getting a new washer and it will not be an LG.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
If it sounds like an airplane taking off the main bearings are gone ,no good no moree dump it
Posted on Jan 18, 2013
sdmc73
  • 121 Answers
SOURCE: grinding noise spin cycle jumping around
what brand
Posted on Nov 29, 2008
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
duby1990
  • 367 Answers
SOURCE: Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Posted on Jan 28, 2009
  • 254 Answers
SOURCE: motor just hums during spin cycle
This sounds like the drive belt may have snapped off. It's usually located on the bottom of the washer. If you're able, tilt the washer on its side and recover the broken belt. It usually connects from the drive motor to the tensioner, then to the transmission. Take the belt to your local appliance parts store so they can match it up with a replacement. You may want to copy down the actual model and serial numbers down so the parts counter can provide a more accurate and exact replacement. Please let me know if you need any further help with this.
I hope this helps! :)
Posted on Sep 22, 2009
My LG WM2101HW washer door will not lock. Sometimes if you shut the door just right, it will work. I ordered and replaces the actually door switch, but it still will not lock. What else can I do?
You say that you replaced the door switch, but you need to check that the spring of the latch hook inside the door is working properly, otherwise it does not hook properly and will cause these problems.
Jul 28, 2016 | LG WM2101HW Front Load Washer, White, 4.0...
In rinse cycle the cold water hose is making a heck of a noise,
Check the screens on each end of the filler hoses to ensure they are clean and sand or rust free.
Mar 09, 2016 | LG WM2101HW Front Load Washer, White, 4.0...
My washing machine makes marks on everything
LG WM2101HW 4.0 cu.ft. Washer Stains clothes ruining ...
www.fixya.com > ... > LG > LG WM2101HW 4.0 cu.ft. Washer
... stains out with anything and they are ruining numerous items of clothing. ... stainson light objects ie making white marks on light blue clothes ruining these ... by greasestains from their front loader Kenmore. .... remove the agitator from a ...
Oct 19, 2015 | LG WM2101HW Front Load Washer, White, 4.0...
My Direct Drive front loader will not intake water
You need to verify power at the inlet water value. If you have power the value needs to be replace
Jan 10, 2015 | LG Washing Machines
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
My dryer makes a horrible high pitch squeaking sound when it is in the dry cycle. It is about 11 years old. GE profile front load.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 05, 2011 | GE Dryers
My two or three year old LG DLE5955W dryer is making a grinding/squeaking noise and from what I have read is most likely the worn rollers. How do you gain access to them and is it something for a do it...
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 09, 2010 | LG DLE5955 Dryer
New LG2101 front loader drum noise
Try rotating the drum by hand and see if you can feel a 'hard spot' If your machine is new you should have a warranty. If so, ring the service line and ask a consultant about the noise. The may even be able to listen via the phone and advise you...Good luck .....Nomess
Apr 19, 2010 | LG WM2101HW 4.0 cu.ft. Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
GE WVSR1060A Top Load Washer Logo
338 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
