My oki television picture goes off after one minute but the sound remains on?
    Top Expert:
  • Televison & ... Master
  • 36,408 Answers
The power supply is failing
Posted on Jan 17, 2013
  • Rob Jennings Jan 17, 2013
    Hi Tom, Can this be fixed?
jerryg50
  • 1667 Answers
SOURCE: screen goes out but sound remains
A blown fuse would not be intermittant.
It is possible that the back plane lamps, and or the back plane power supply is failing.
When the set is in the dark screen, shine a flashlight on the screen at an offset angle. Look carefully and see if you see the picture images. If so, this proves that the back plane lighting is having a fault condition. If there is no image at all, then there may be a fault condition with one of the drive boards for the picture processing or the screen itself.
Jerry G.
Posted on May 17, 2008
Shuttle83
  • 1139 Answers
SOURCE: samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 16, 2008
xCAUSALITYx
  • 210 Answers
SOURCE: picture goes off after a few minutes but sound
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Thanks
Posted on Oct 02, 2009
  • 175 Answers
SOURCE: Picture goes black, sound OK
is it under warranty, it could be the ysus or the panel
Posted on Apr 27, 2010
caroldon
  • 17130 Answers
SOURCE: About 5 minutes after TV
This is a common fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Posted on Aug 17, 2011
New power supply board and screen goes black
It sounds that the off timer has been set to one hour. Check it.
May 29, 2013 | Philips 47PFL3704D 47 in. LCD TV
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
Apr 27, 2010 | Olevia LT37HVS 37 in. LCD HDTV
TV picture goes off after 20 minutes
there are bad solder connections on the pictury tube drive module. have it fixed at a repair shop.. the tech will be mystified that you know what the problem was..lol..
Nov 12, 2009 | Televison & Video
When initially turned on TV will alternat between picutre & black
When the tv goes to a black screen does the sound remain on? Also,if you listen carefully can you hear any arcing noises in the back of the tv?
Aug 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Screen goes out but sound remains
Jerry G.
May 14, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
No picture but have sound
Solder any / all bad connections , esp. vertical output IC......
Nov 07, 2007 | Quasar SP-2719 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
