Question about Xante CL30 HSE Laser Printer
How to replace fuser fan on xante cl30 hse - Xante CL30 HSE Laser Printer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
It's not easy to describe it. The fuser fan cover has some screws, remove them and then remove the fan, it's a little tricky. From my experience, the new fan has small cables. What i did is to cut the cables of the old fan and attach them to the cables of the new one. My suggestion is if you don't feel confident, leave to a more experienced technician.
Posted on Nov 02, 2013
3 Suggested Answers
  • 6 Answers
SOURCE: Xante cl30
If the printer is still under warranty, and a new yellow drum doesn't fix the problem, or if you install a new drum and the problem returns, Xante should provide you with warranty support. This problem can be caused by a defective high voltage power supply, and that is not a user replaceable item.
Posted on May 28, 2008
  • 6 Answers
SOURCE: Poor registration on Xante CL30 HSE
Make sure the drums are properly seated in their cradels, and if posible, avoid designing with white small text in heavy solid areas that are made up of process colours. For reverse type in a black background, use spot color black rather than rich black. Other than than printing on a not as heavy card, that is about all you can do.
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
Xante cl30 printer drivers for windows7 32bit & 64bit
go to www.xante.com -->support -->drivers & docs -->legacy products -->cl30
Aug 20, 2012 | Xante CL30 HSE Laser Printer
177 Fatal Error
Error 177: Thermistor indicates Low Temperature (COLD) Error.
Usualy the fuser has overheated first (error 172/176) and tripped the thermal protection causing the fuser not to heat up anymore.
Normal procedure if a restart doesn't fix it is to replace the fuser unit.
Dec 29, 2010 | Xante CL30 HSE Laser Printer
Xante CL30 Fatal Error 127 Code
When to many consumable is low at the same time.
Oct 08, 2008 | Xante CL30 HSE Laser Printer
Xante cl30
May 02, 2008 | Xante CL30 HSE Laser Printer
Xante cl30 color laser printer paper jam
Remove the fuser and examine it closely (Note: the fuser gets extremely hot. Wait until it has cooled completely before touching it!) Paper or a paper fragment might be balled up inside it.
Even just re-seating the fuser might clear the sensor that is reporting this jam.
If the printer continues to stall with this error code, even though there is no jam, it could have a faulty sensor. This would have to be repaired with a service call...
Mar 06, 2008 | Xante CL30 HSE Laser Printer
Xante CL30 printing streak line in middle of the paper
make sure there is nothing on th belt of the unit
Oct 25, 2007 | Xante CL30 HSE Laser Printer
Aug 19, 2007 | Xante CL30 HSE Laser Printer
Xante CL30 HSE Laser Printer Logo
59 people viewed this question
Top Xante Office Equipment & Supplies Experts
Igor Studennikoff
Igor Studennikoff
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
