How do you set time on a teltime wall clock - Audio Players & Recorders
2 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Posted on Mar 19, 2010
How can I set the time?
Once you select the time zone and whether you are observing DST, the clock sets automatically. That's the point of having an atomic clock.
Apr 19, 2016 | Sharp Atomic Wall Clock, Silver/Titanium...
How do i change time
look on the back of the clock U will see how
Mar 29, 2015 | PT Present Time Wok Time Wall Clock, Metal...
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    I have a lacrosse technology wall clock how do i set the time
    You don't set the time. You set the Time Zone and it sets itself.
    What model is YOUR clock?
    This site lists several models of La Crosse wall clocks with downloadable instructions.
    http://www.klockit.com/depts/AtomicClocks/dept-52.html
    The link below is generic but there are specifc downloads for clocks with other features.
    http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
    Jun 18, 2010 | La Crosse Radio Controlled Atomic Clock
    Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    John
    Apr 21, 2010 | Watches
    Bill B
    Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
    AI can't figure out how to set the atomic clock
    This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
    If it does not correct it;s self change walls and location in your house.
    The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
    Hope this tip helps.
    R/
    David
    Feb 13, 2010 | SkyScan 86709 Atomic Wall Clock
    Seth Thomas wall clock wont set to time.
    either the battery is weak or the gears inside are stuck and need to be worked with flathead or eyeglass repair screwsdriver.
    Jul 06, 2009 | Seth Thomas Radio-Controlled Howard Wall...
    Have a radioshack atomic wall clock model #
    1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
    2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
    3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
    4. The year digits blink. Press + or - to select the year.
    5. Press WAVE/SET to confirm the year setting and enter date setting mode.
    6. The date digits blink, press + or - to select the time.
    7. Press WAVE/SET to confirm the date and enter time setting mode.
    8. The time digits blink, press + or - to select the time.
    9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
    10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
    11. Press WAVE/SET to confirm whole setting.
    SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
    I hope this helps. I work for radioshack and i had a few extra minutes while at work.
    Brett.
    Mar 11, 2009 | SkyScan 86709 Atomic Wall Clock
    Time not correct
    press mode button once.
    Then press set until the time zone is on the correct setting
    then press mode again
    Dec 22, 2008 | SkyScan 86742 Digital Atomic Wall Clock
    160 people viewed this question
     Grubhead
    Grubhead
