Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
How to get a warenty replacement unit
Failed under warenty need a new unit
  • 3,289 Answers
First, you'll need to gather all pertinent info- including model / serial number and any paperwork indicating date of installation or purchase.
Next, go to Rheem's website. There is help there to assist you to locate your heater's model and serial number if you are unable to / unsure of where to find it. If you live in the U.S. and have the model / serial number data, you can go to the Homeowners Resource Center page and click "Water Heating Product Warranty Verification" link inside the Warranty Section. If you live in Canada, you cannot use the online verification and should call 800 263 8342 instead.
I hope this helps & good luck!
Posted on Jan 17, 2013
My hot water light wont go out,my central heating wont come on either but I do have hot water
I'll need to know what make--model--- age of this unit is and if it's electronically controlled to help you----your question is too vague do to the enormous variety types of heating systems----I'm going under the info provided that this is a boiler with domestic hot water coil----you say central heating so this throws me off---do you heat with hot water--hydronic-----or forced hot air----if hydronic---it sounds like your circulator in not functioning----a bunch of reasons circulator has failed---aquastat's "circulator control" has failed---thermostat has failed----broken wires----plugged lines----it goes on and on----this is the best I can do with this info sorry Happy Rabbit
Apr 02, 2015 | Water Water Heaters
GE Water Heater, Calrod, failed after power outage
Check the power is good to the heater then check there is power on the elements. That will tell you exactly where the fault lies.
Feb 01, 2018 | General Electric Water Heaters
Error Im getting is C8 82
Before calling service tech, copy following link for Rheem-Paloma troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
C8 is usually the PC board, or could be failed gas solenoid valve.
82 is gas-type-data-failure = program PCB for proper gas type, or proper altitude above sea level.
If this is new installation, Rheem-paloma might tell you to contact the installer.
If this is older tankless that worked before, then things point to failed PC board. Rheem-paloma may send you new PCB for free if unit still under warranty period for defect parts.
Rheem does not post service manuals, but will send instructions.
Hopefully the success rate for replacing your main PC control board will have better outcome than expected when replacing motherboard on your computer.
Perform regular maintenance to avoid some common error codes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 16, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Replaced my Disposal forgot to push the punch out, the dishwasher never had a chance to drain. The heat element no longer works. Does whirlpool Quiet 1 series have a default breaker of reset button?
there is no breaker but there is a thermostat limit under unit where you also have to access the wires to the heater on this unit. may have tripped out this device it will be round small metal, it should not have damaged if water was left in unit i am willing to bet the heater just has failed. if you get to bottom of unit and remove wires to heater test and see if you have contuinity through heater should read through it. if no contuinity then it is bad and will need replaced...
www.sears.com is a site you can order parts from
Mar 01, 2011 | Whirlpool Dishwasher Water Heater...
Hi, my insinkerator hot water dispenser is leaking from the bottom screw. It is a couple of years old. Moder SST
My unit is 3 1.2 tears old. It started to delay the flowing of hot water. Today I held the lever down until hot water came out but I noticed water leaking from inside the unit. I figured that the tank failed, and since it was over 3 years old I decided to open it up. What I found was that there is a plastic tube at the top of the unit that was very discolored and brittle which developed a crack. when I touched it it completely severed. I called the Insinkerator hotline at 1800-558-5700 and they told me that opening the unit voids the warranty. I said that it appears to be out of warranty and I needed just the plastic tube for repair. The per on on the phone said that as a one time courtesy that a new unit would be shipped to me free of charge and that I could install it myself or they will have a tech do it. I opted to do it myself. Hope this helps
Nov 05, 2010 | Emerson InSinkErator W-152 Point-Of-Use...
Pilot liht wont stay lit on hot water heater.
You will need a new thermo coupler to keeep the pilot ight on. It is a probe that touches the pilot flame to sense the the regulator to feed the gas flow. Upon failing it shuts off the gas to the regulator so the unit does not catch on fire. In other words it is a fail safe part that is required
Apr 12, 2010 | Water Heaters
Just under two year old C-4 76 CODE SOME WATER
the 76 code is a code for the remote control. if you have a remote installed check for loose wiring or it could be a fried remote disconnect it and see if it runs then
Jul 08, 2009 | Rheem Tankless Hot Water Heater...
Our second unit just failed and needs a new controller more money
The only Bosch tankless I have ever touched have been the 3 I have taken out and replaced with Rinnai. I think Bosch/Paloma/etc. have two problems:
1. They do not properly certify technicians before allowing them to install these units.
2. Their product is mediocre at best.
The biggest problem I've seen is that people don't vent them properly. The last one I pulled out had a combined vent length of 55'. 55 FEET! Absurd!
The units was condensing so much inside the vent that it washed out 2 gas control valves in ONE YEAR.
Buy Rinnai, buy Takagi, buy Noritz....maybe even a Navien (new player...time will tell)
Factory certified technicians, preferably equipped to do the gas & plumbing without having to sub it out.
Years of trouble-free hot water.
Good Luck.
Jun 30, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
32 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
