Question about Maytag MER6775A Electric Kitchen Range
Maytag gemini M# MER6769BAQ
My lower owen door is locked after cleaning and will not open.
  • jeffrey wilson Jul 13, 2007
    I tried to reset it it still won't unlock.
  • brianf Jan 09, 2008
    i have a maytag gemini oven and i,m getting a f5-9 fault..lower door will not unlock. i have tried unplugging it. but the fault still comes back. how do i check the lock to make sure it is working right. thanks
  • 432 Answers
Turn off the circuit breaker to the oven for a minute. This will reset it. This little trick works on most ovens that are locked. The oven should cool for at least two hours before doing this. Let me know if this works. Because there is still an issue of it locking again
Posted on Jul 13, 2007
  • Anonymous Jul 13, 2007
    Got cut off, hit the wrong key.
    There is still an issue of the oven not unlocking after cleaning. Sometimes it can take up to four hours before you can open it.
SOURCE:
What is Error message F9-5, bottom oven door is locked
Hello & Welcome to FixYa
Error F9-5 in your Maytage Gemini means Latch unlock lower and is displayed due to obstruction in door lock mechanism. If after cleaning the door lock mechanism the problem is still there then replacing the door lock mechanism is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 08, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Lower oven door locked and unable to open the door.
I have the same problem. Happened a few days ago. Have you found a solution?
Oct 30, 2010 | Maytag Gemini 30" Self-Cleaning...
Getting error code 9-6 on MER6770AAW maytag gemini double oven range...what and how to fix?
That code is for obstruction in the lower door lock mechanism. You need to check for a obstruction in the lower door lock. The next step would be to disconnect the power for a few minutes then turn it back on and see if the code reappears.
Feb 23, 2010 | Maytag MER6772 Gemini Electric Kitchen...
The lower oven door locked shut. Accidently pushed wrong button & lower oven locked and I can not get it to open.
stop pushing all the buttons. Turn the power off for a few min. It should un lock when power is back. If not set clock, set oven into clean cycle, wate a few min then hit cancle. wate till door unlocks. If nothing happens make sure you dident hit the child lock button. It looks like a pad lock on touch pannel. push and hold it to unlock. Re try clean cycle. let it lock then wate ,then cancle .
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Lower over door won't open
The first thing to check is the oven sensor you will have to purchase a new one and have a local service co. come to put it in and unlock the door for you. good luck
Dec 20, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Electric Oven - Lower is not locked, but will not open.
Usually, starting with a COLD oven, turn the self clean on. Wait 3 minutes, then turn it off [cancel] WAIT 1 minute at least, do not immediately pull on the door. This should reset the lock sync. If you cannot get it open still, you may have a faulty sensor that thinks the oven is overheated, or at this point you could have a bent actuator rod from all the tugging!
May 01, 2017 | Maytag MER6772 Gemini Electric Kitchen...
F9-4 when cleaning upper oven
its related to the self clean ltach motr, if you pull hte unit out and drop teh rear panel, approx halh way down on theright side( when behind unit) thers asmall lock mechinisn mavbe 1.5 round, with a connecting rod 2 wires and a witch, well that motor sometimes as it heats looses connection with the switch. the switch is monitoring door positoin so if it loses contact it thinks the door is open and will trigger a code. the entire latch is replacabel (FRont to back comesa sone assy latch motor swittch and rod. 2 wires connect it and 2 screws(by front latch secure it. if youtry to replaceit your self i giveyou the heads up to lie a yard stick on top of latch before removing old latch (thos will keep the insulation in place) andthen when installe ing new latch also use hte ayrd stick ontop to keep insulation inplace!!!!!
Feb 24, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
Dec 18, 2007 | Maytag MER6872BAS Gemini Electric Kitchen...
Maytag stove with a F 1-3 fault
  Have seen lock motors go bad on these.  Probably happened due to self clean heat.
Oct 11, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6775A Electric Kitchen Range Logo
328 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
