Question about Food Mixers
Kenwood chef km330 speed slowly dies
My kenwood chef KM330 start at normal speed for 10 sec then it suddenly slow down hardly spinning at all
  • 9 Answers
SOURCE: kitchenaid mixer not mixing
remove the back cover, and try tightening the two (on top) adjustment screws.  that might help but no guarantees!
Posted on Jan 27, 2008
SOURCE: Kenwood chef 700w
I hope you didn't buy a new one, ours stopped last week after 25 years. All that was needed were new brushes for the motor. Anyone with a screwdriver could replace them. 4Kenwood had the parts to me in a couple of days.
Posted on May 31, 2008
IrishDruid
  • 2712 Answers
SOURCE: Kenwood Chef A701 Variable speed controller
U have a problem with the rotor.. Need to get it serviced..
Posted on Aug 07, 2008
alexpomar
  • 26 Answers
the solution its change the capacitor or triac, normaly problems in models A701 or A901 old motors
regards
kenwoodchefrestore.co.uk
Posted on Aug 19, 2008
alexpomar
  • 26 Answers
SOURCE: Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Posted on Jan 22, 2009
Kenwood chef keeps curdling eggs
Put water in Kenwood and a bowl inside the Kenwood to hold eggs. Eggs need to be done SLOWLY. Can also add a LITTLE water to aggs as they cook to slow down curdling . Basically you need to turn Kenwood into a double boiler. Lift bowl with eggs in and out of Kenwood to control temperature and whisk away now under control. Lift bowl and cool and slow down cooking and lower back in water and Kenwood to hear back up. Keep whisking and lift and lower bowl as needed. Some melted butter doesn't hurt either!
Jan 11, 2015 | Kenwood Food Mixers
Kenwood Chef KM001 Service Manual or help with motor speed?
Hi I am also looking for a service manual for KM001.
Please BGR1 can you email me this manual if possible. I am having the same intermittent start problem as this person who asked the question to you.
My email address is jk@connectafrica.info
Apr 21, 2012 | Food Mixers
Kenwood Chef KM400 motor speed is too slow
A failed SCR or triac will not always show visually any sign of failure. Chances are good that is all that is wrong. If mixer had been plugged in when it got wet, that is all it takes. Also check the transient voltage supressors if the chef has them. They would be identified on the circuit board. as TVS or MOV along with a number. Only number to use is the one on the component.
If you can find ratings for the old devices, just matching the basic ratings should do. Just guessing, but the SCRs should be 20 amp and 400 volt, If the old ones are a lower rating than my guess, there is no problem with using the higher ratings, if my guess is low, go with the original's ratings. Manufacturer of device does not matter as long as ratings are at least comparable.
Jan 19, 2012 | Kenwood KM400 / KM410 Chef Classic Stand...
K5SSWW Stand mixer started slowing down while grinding shrimp
I'm not quite sure about this answer but it occurs to me that it could be the governor. It sits at the back end of the armature and as the speed control is slid to faster speeds the governor moves away from its rest position pressing against the control plate. If the governor's pivots were to be binding, even slightly, it would explain the symptoms you are describing. A service manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Apr 28, 2017 | KitchenAid K5SS Heavy Duty Commercial...
Kenwood Chef - slowest speed
if you have max speed you have to replace the .1uf capacitor the 2 spring loaded screws serve far fine adjustment
Feb 02, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Hello.
high speed outlet
slow speed outlet
A9 = A901 and KM
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
My kenwood mixer will not mix, the liquidiser works ok but the mixer rotates very slowly.
Hi, maybe you have 3 problems:
1 the tooth belt its nearly broken.
2 Problem in some gears
3 If its model A701/A check the back cover, and the pin in the top. its in good condition
regards
Jul 02, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood chef 700w
I think its the control modul that has stoped working ,sadly.
Mar 13, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kenwood 500 watts
It may be the motor but it is most likely a burnt out capacitor, these can be replaced for around £30. It is not a DIY job unless you know a qualified electrician as soldering is involved. Best to take it in for repair if you think it is worth it.
Jan 04, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Food Mixers Logo
63 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
