Question about Staples Arrow T2025 Staple Gun For Flat & Round Crown
Staple gun will not shoot staples gun is a true value #659-224
No tension when i try to shoot staples
2 Suggested Answers
SOURCE: (DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Posted on Jun 28, 2009
Powershot, heavy duty, forward action, staple & nail gun will not shoot staples
If you are referring to a Swingline powershot model 1000, you may try using the following staples for best results: True Value part # 659857 for 1/4" staples or True Value part # 660426 for 3/8" staples. You may also find these staples at Sears under the Sears part #: 1/4" is part # 74417 and 3/8" is part # 74418. I hope this helps, often times, using an incorrect staple will give you undesirable results.
Oct 07, 2012 | Tools & Hardware - Others
Cant find staples for swingline 101 tacker
Hi, Last time I bought them from amazon, here: Amazon com Swingline Heavy Duty Staples 1 4 I hope this helped. Have a nice day
Feb 12, 2012 | Tools & Hardware - Others
The info on the gun says it will shoot many different staples, but it will only take 3/8 staples and I need to use 1/2 staples to do the job.
The T50P stapler uses T50 staples of various lengths, including 3/8, 7/16, and 1/2. Is it possible that the 1/2 inch staples you are trying to use are not T50? All T50 staples are the same width and should fit your stapler. There are several other widths of staples that are not T50, although T50 is the most common.
Nov 29, 2010 | Arrow T50P ARROW STAPLE GUN
Gun shoots but no staples coming out, part that
try carefully tapping it in with a nail punch and hydraulic tool oil
May 15, 2010 | Tools & Hardware - Others
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Hello. I have a model #1000 Swingline Power Gun. It says,the extra heavy duty staple gun on the handle. I would like to purchase a box of 1/4" and 3/8" staples. The gun is so old I don't know the new...
Went to the local hardware and read the labels. The store brand fit and works as good as the original staples. The 1000 has outlasted several of the new fashion staplers. And the local hardware store is an Ace Hardware.
Jan 20, 2010 | Staples Swingline® 36115 Staple Guns Tools...
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Jun 06, 2009 | Staples Tools & Hardware - Others
Staple gun has staples but quit working.
I hae the same problem. I don't know the real names of the parts so I will make up my own and try to describe them. The problem with mine is that the "hammer" (the piece in front that slams down on the staple and shoots it out) is broken. The "hammer" has two notches that the tension spring (actually a metal bar with two tongs not to be confused with the spring the returns the handle to the at rest position) fits into. One of these notches on the hammer is broken. Therefore one side is not attached to the tension spring the causing the other side to slip off and since the hammer is not connect to the tension spring you get no resistance. Unfortunately I could not find anywhere that sells a replacement peice.
Sep 18, 2008 | Black & Decker 5700 Powershot Forward...
Staples Arrow T2025 Staple Gun For Flat & Round Crown Logo
158 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
