Am trying to conect new power module to my hotpoint wd865a wash/dryer need a wiring diagram
  • Washing Mach... Master
  • 17,130 Answers
If you are replacing with the same type for the model , you can remove and connect the connectors as designed.
click this link for tips: Front Panel
Posted on Jan 18, 2013
gittos73
  • 244 Answers
SOURCE: hotpoint ultima wma62s
it possible isnt the heater elemant it will more then likely be your thermostats which are close to your heater element change both i always have so i dont need to go back to a customers house to change the other at a later date m8
Posted on Feb 24, 2008
IFIXALL
  • 868 Answers
SOURCE: Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Posted on Jun 03, 2008
ngafm
  • 166 Answers
SOURCE: HOTPOINT WF00
Deasr dashdach
Peace,
From ngafm,
I understand that you have,
HAVE REPLACED DRUM BEARINGS, MACHINE RUNS,BUT WILL NOT COMPLETE WASH CYCLE ( FILLS, WASHES BUT WILL NOT MOVE ONTO SPIN ) TRYING TO GET WIRING DIAGRAM TO CHECK I HAVE RECONNECTED THINGS IN RIGHT PLACE !
How old is this washer that you are spending so much money in parts for?How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Sounds like you really need a Hotpoint trained tech , so as not to spend weeks repairing, or not your washer.
My father and grandfather used to teach me , ("When in dought, don't)
If I were there I could show you the wiring order without the diagram!!!!!!!!!!
In the USA thousands of deaths and house fires happen when corners are cut, and cost home owners much more than the few bucks they plan on saving!
Do it right, like the rest of the things you did in you life to get this far!
Call a factory service and let them help you.
Stay healthy!
You will be fine.
Bless You,
ngafm1
Please give me a good rating for this fine advice i give you, before you sign off.
Thank You
Posted on Sep 10, 2008
  • 100 Answers
SOURCE: how to clean the filter
the dryer filter is in the dryer box on top of the drum, under the lid of the machine at the rear, sometimes has a grey hose going into it, the box will have to be removed and split to access it.
the wash filter will be either at the front of the machine behind the kick plate or at the rear behind the lower panel attached to th bottom of the drum.
Posted on Feb 25, 2009
  • 62 Answers
SOURCE: Control Module WMA34
If my memory serves me well, the plugs/wires will only fit the correct spots on the module, and I believe there is a "jumper" on the original module, make sure you remove and install in the new module..Good Luck
RMK
Retired GE Technican
Posted on May 21, 2009
Wiring diagram WMF740 MODULE
Contact Hotpoint directly to request the wiring diagram.
May 01, 2017 | Hotpoint Washing Machines
Replacing bushes hotpoint wdf740
check the length of the motor brushes.
new are about 30mm long.
should also clean up the motor with compressed air.
Remove the electronic module also do a cleanup in all contacts of connectors. If necessary wash with isopropyl alcohol which can be purchased at a pharmacy.
Dry with a hair dryer.
Do not forget to make reset to clear the error.
(Pressing the start button until all the LEDs light up)
Dec 21, 2013 | Hotpoint Aquarius WD640 Front Load...
I have a hHotpoint washer/dryer model no WD865A. During A wash cycle it flipped the household relay off. I reset the relay pressed start. This was followed by a bang, similar to a capacitor blowing, The...
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
I've repaired the bearings in my wf000 hotpoint washing machine, put it back together now it won't pump the water in, and the door lock light does'nt come on! any idea's wot is wrong?
I would say you have missed a wiring connection somewhere or connected the module up wrong. Hopefully you noted where all the terminals came from when you dismantled it or you may need a wiring diagram.
Mar 16, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Where is the 7.5 amp fuse in the hotpoint WD71?
the 7.5 amp fuse is near the power module, This fuse is on the motor circuit to protect the circuitry of the power module. If it blows the motor won't work .hope this helps
Dec 22, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint WD420 Dryer heater relay
You must check for overload try to messure the amount of clothing you adding to the machine, and try to restart by unploging the aparat from the wall outlet, wireing diagram are located usualy on the back of the aparat.
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
RMK
May 19, 2009 | Washing Machines
How to clean the filter
Feb 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Need wiring diagram to conect pcb to a hotpoint ultima extra wma66
www.selfix-uk.co.uk for manuals on WM & WMA machines including wiring connection charts
Feb 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wiring diagrame for hotpoint gas dryer
E-Mail me and I will send you a copy of my Schematic. It's 2 pics, but they are pretty clear and should help you. I came to the site wher I saw your post looking for a pic of an exploded view of our dryer. Trying to open it to fix the glide bushing. Started makin metal to metal noises lately, so I am assuming it's like a nylon glider for the drum?
SyxPakk@Yahoo.Com
Mike.
Feb 19, 2008 | Hotpoint NVL333GY Gas Dryer
Washing Machines Logo
Top Washing Machines Experts
