Question about Watches
I have Longines Vintage Watch 5 Star Admiral - Watches
I have Longines Vintage Watch 5 Star Admiral Automatic and at the back of watch is Gold with sayings of 10K Gold Filled, Remove Bezel to use 1260 wrench. If there's anybody knows the details like Year it produced and how much it to be sell if ever someone is interested into it. Thank you.
I have a Benrus antique watch serial # 445178
Fixya does not do appraisals.
Feb 04, 2018 | Watches
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
I have an old (1991) Corum Admiral's Cup watch and need to remove some links. How do I do that? Thank you for your time.
mcdevito75 Here, You"ll need a special toll called a link remover tool, available on ebay, however if you"ve never done work or this particular work on watches, your best bet is too find a small watch repair shop in your area for the link/s removal.
Sep 01, 2010 | Corum Admiral Cup 18K Yellow Gold Blue...
Dear Sirs! My new (1month) Longines automatic watch hastens each day (and night) four seconds.Model L4.721.2 Is it normal or I have to turn to the laboratoty to fix the problem?! Thanks a lot Iosif
An automatic watch that gains 4 seconds in a day is good.A new Rolex is rated at 5 seconds per day so 4 seconds is well within what you can expect for your watch.As a tip when the watch is off the wrist place on its side,gravity slows the operation of the watch just a fraction.This is called positional error and may help.
Regards
Aug 19, 2010 | Longines New La Grande Classique Presence...
I WOULD LIKE TO ITS TRUE VALUE
mcdevito75 here, Many factors figure in the value of a watch, Of course you have a NAME watch Longines which helps a great deal, First, if the hands are thick, the watch is before 1969, if they are thin, anywhere after 1969, Original strap or band conts, a good, good replacement band is ok. the appearance of the watch, no scratches opr buffing, scrapping on the caseing, no scratches or cracks in the crystal (glass) of course being vintage there will be some evidence of age, and lastly time keeping, if your Longines works well keeps time all day, I estmate it"s value, anywhere from $125.00--------- $200.00. You can also check a small watch repair shop in your area or jewelery shop, they will usually give a rough estmate of value for free.
Jul 17, 2010 | Longines 10K Gold Filled, Manual Wind...
If I buy a Longines 10K gold filled watch, what is the difference between that and solid 10K gold? and is there a big difference in the price of 10K gold filled per gramme and solid
Gold filled is simply a very thin layer applied to the base metal case and will wear off over time. Solid 10K gold is an alloy that is mixed with gold throughout and will always retain it's color and never wear off. The solid 10K gold case contains a lot more gold than then the gold filled version and will cost more up front. However, the gold filled case will look awful in a year or two while the solid 10K case will last as long as you keep the watch and beyond.
Apr 22, 2010 | Longines 10K Gold Filled, Manual Wind...
How do i set an older longines automatic admiral watch to the correct date and day
You can get instructions from their web site but if your watch is really old, then it seems unlikely that any of the instructions there are for your watch.
However, since watches tend to have similar features (although not the modern electronic types), a basic modern watch probably operate in the same manner.
Go to "www.longines.com/watches/instructions" and have a look at the range of instructions there to see if they are any help.
If nothing useful is found look at the "official retailers" to see if there is a local shop that can help you.
Mar 08, 2010 | Watches
Hello, my longines 14k 17J, case number 975099 Can you help me find the information about this watch?
Contact Longines yourself by following this link: http://www.longines.com/contact/faq/products Find the best suitable way for you to get in touch and ask for the information you are after. Rate me, plz.
Jan 28, 2010 | Longines "Fancy Case" 14K Gold, Manual...
Face almost unreadable;can only adjust winding back;stops intermittently.
Hi Murbilpov,
thank you for using fixya, you have a very fine piece of jewelry. it appears that your watch needs cleaning right on the knob and adjust mechanism. as per a service document from longines, a possible build-up or a broken first gear may cause this issue.
you may refer to their official statement when it comes to cleaning and having the watch repaired.
1) Where should I send a Longines watch that needs to be repaired, adjusted or serviced?If your Longines watch needs to be repaired, adjusted or serviced, werecommend that you bring or send it (well padded and by registereddelivery in the latter case) to your nearest Longines authorizedservice centre. You will find its address in your guarantee booklet oron our website in the Customer Service section.
2) Is the repair of a Longines watch that is more than 20 years old still possible?Yes, we still repair vintage watches at our head workshop in St-Imier.
However, without having the watch to hand, it is impossible for us tojudge its state and to know if all the necessary spare parts for therepair are still available.
Therefore, we kindly suggest that you send your watch via the nearest Longines authorized servicecentre to the Longines head office in Switzerland. Upon receipt andafter analysis of your watch, we will send you our comments and a priceestimate for the repair of your watch.
3) How often do you recommend having a maintenance service carried out on a Longines watch?We would like to draw your attention to the fact that a watch used daily is running 24 hours a day, 7 days a week non-stop.
The frequency of the maintenance service depends on the type of watch, the climate and the care taken by the watch wearer.
In general, it is necessary to have your watch controlled andserviced at least once every 4 - 5 years, just like any other precisemechanical device. This guarantees the reliability and rate precisionof your watch.
4) Which operations are included in a complete maintenance service?The following operations should be included in the price of a complete maintenance service:
– complete dismantling of the movement, cleaning, oiling, reassembling, regulating and the checking of functions;
– repair or replacement of movement components that are either worn or faulty;
–replacement of the following parts: glass, crown, push-pieces, sealsand battery if a quartz calibre (parts included in the price of theservice, with the exception of shaped mineral glasses and sapphirecrystals);
– restoration of the water-resistance (if a water-resistant model);
– refurbishing of the case or bracelet (two-tone, gold-plated and PVD-coated cases and bracelets, cleaning only);
The above service standards are only valid for the Longines head office in Switzerland.
5) Which operations are included in a partial maintenance service?The following operations should be included in the price of a partial maintenance service:
– during each partial basic repair, Longines undertakes to check theregulation of the movement and replace the glass (if necessary), thepipe, the crown, the push-pieces, the seals and the battery in the caseof a quartz movement (these parts are included in the price, with theexception of shaped mineral glasses, sapphire crystals, and restorationservices carried out on the dial, case and bracelet. Parts made out ofnoble metals will be invoiced separately);
– restoration of the water-resistance (if a water-resistant model) and cleaning of the case and bracelet;
Any repair that necessitates the replacement of a part, or any servicementioned in point 7 automatically involves a partial basic service.
Hope this helps, should you have other questions, please do not hesitate to let me know.
regards,
voodoo
Apr 22, 2009 | Longines Watches
Ebel Classic Wave fitting a new crown
i have changed the battery on my and my wifes ebel classic wave watch,,
step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
step 2 ...remove all 5 gold bezel screws
step 3... be careful,, the bezel/crystal will pry off easy
step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
step 5.. small screwdriver and remove/replace battery
step 6... reinstall watch guts/bezel and gold screws
step 7... push crown back into watch
step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
if have done it many times ,, you can do it !!!!
Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
Watches Logo
517 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
