Question about Compaq Presario 700 470024-192 Notebook
Please i can't remenber the admin password to the bios setup of my compaq presario c700 to enable me disable the sata native option and continue with installation of window xp. please what do i do?
  • yesenia600 Jan 26, 2009
    Hello there i have the same problem tried that adn ti didnt work..I have a Compaq f700 vista forgot password cant log in any other ideas?
  • seanrocks360 Jan 26, 2009
    forgot the administrator password for my compaq c700 as well looking for an eseier solution the one solution i keep finding is a paintaking six major component removal of up to 79 screws to get to what would be the same as the cmos battery in a desktop remove it wait 5 minutes hook it up turn it on and this should reset the password then you have to put it back together and hope you can remember the location of all those screws which are also in nine different sizes. I found the manual with step by step instruction at http://h10032.www1.hp.com/ctg/manual/c01... - Windows Internet Explorer ....but if any body knows a different faster esay soultion that does not involve buying software I would appreciate it very much!! my email is seanrocks360@yahoo.com
    President:
  • 1,179 Answers
To reset the bios password you will need to remove the cmose battery from your motherboard for about 5-10 seconds. Replace & reboot. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 25, 2009
CampacPresario C700, i want format to system prasently working windoew Vista home p but i want change t operating system installed to XP to showing error hard disk not available.pls help
go to the BIOS settings find SATA hard disk enable/disable (should be disable), OR if it is showing something different like SATA , PATA, IDE....then u have to change SATA to IDE save and exit from BIOS,run the setup again. good luck.....
Sep 16, 2011 | Compaq Presario C700T Notebook
Windows could not start because the following file is missing or corrupt: WINDOWSSYSTEM32CONFIGSYSTEM. I try to repair it by using setup CD-ROM recovery consule but setup fails stating setup did not find...
Hi
I wanted to know which os you are trying to install on this model if it was installed with vista os and now you are trying to install the xp
You will get this type of issue
Check for the SATA Native support in the BIOS
> To Check in BIOS - Shutdown the notebook as soon as you power on the notebook keep tap on F10 key - go - to - system configuratoin- check for the SATA Native option - status should show as Disable.
> Then also if fails - Scan for the Hard Disk drive in the bios
Select - Diagnostic- Run long and short hdd test.
With Regards
anand_manj2005@hotmail.com
Apr 09, 2009 | HP 435768-001 - Compaq Presario C300...
Cant find operating system
presario c700 is coming with vista not with xp. so how u got xp recovery disc?? check the bios for enabling (for vista) or disabling (for xp) option for sata drive
Apr 03, 2009 | Compaq Presario 700 470024-192 Notebook
I can't downgrade Vista to Xp
You can install windows XP.
First go to BIOS and change sata mode to IDE mode
or option to disable SATA Native mode
then choose mode to IDE or disable SATA Native mode
then install windows XP
If there is no option about change sata mode in BIOS.
You should insert ahci driver to Windows XP CD using nLite
read this
http://komku.blogspot.com/2007/11/integrate-driver-into-windows.html
you can use this driver
http://cahya.prastyanto.googlepages.com/driver-sata-ahci-4920.zip
Or you can install windows by inserting driver when setup prompted
To install Windows XP with native SATA driver, perform the following steps:
Boot the notebook PC.
Insert the Windows XP installation CD into the optical CD/DVD drive.
Press the F6 key when prompted
Press the S key to specify the additional device.
Insert the SATA driver disk into drive A. (using floppy disk drive)
Follow the on-screen prompts.
Or if both way is cannot be done
i have the third way
use an unattended XP installation disk
you can download it from here:
http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
after you download
burn the CD image to the CD/DVD
then install XP using that CD/DVD
Jan 24, 2009 | Compaq Presario C700T Notebook
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
Installing XP to C700
First disable sata native support because after installing xp and restarting will crash it.so disable sata native support now when installation of window xp is complete ,reboot the computer and enter bios and select the first boot device to hard disk and also disable cd rom boot to disable .by doing this when computer starts it will start with hard disk and not with cd rom .
________________________________________________________
If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Compaq Presario 700 470024-192 Notebook
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
Compaq Presario 700 470024-192 Notebook Logo
286 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
