Question about Toastmaster Kitchen Appliances - Others
Toastmaster model 1B16 does not toast one side, manual available?
Does not heat one side Is it repairable? Need manual
  • 979 Answers
Yes it is repairable, and not that difficult to fix. Call for manual. They will send one.
Posted on Jan 29, 2013
3 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: Can an old Toastmaster toaster be refurbished?
there is no manual forthe repair of toasters . but the toaster you have is a common one on e bay , i dont see one right now but there have been a few over the years , and a well used one sells for around 10.00 , it may not work but its great for parts ( i collect and restore kitchen appliances) so i would take a look . you might find a cream puff for 20 .00 and put yours into retirement ..... other than e bay there not a lot of resources out there for parts . good luck ........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 06, 2009
espressonist
  • 1711 Answers
SOURCE: Our 4-slice toaster (model 4cbc) is only toasting
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Posted on Apr 02, 2010
Toastmaster B1042 toasts only one side of one slice and both sides of other slice
The is by design. The bagel side only heats on one side because of the bagel not needing to be toasted .
Jan 16, 2013 | Toastmaster Kitchen Appliances - Others
Toast master model 1194 user manual
I have the manual for the toastmaster model 1193 not the 1194. If interested contact me through the website breadmachineshelp.com
Dec 30, 2012 | Toastmaster 1193 Bread Maker
Wont pop up old toastmaster toaster
Hi mon42,
The 'click' sound indicates that the pop up mechanism is most likely intact. The problem of not popping up is most certainly caused by a worn or broken or disconnected spring which forces the toast to pop up once it's done.
You will need to take the toaster apart and look for the mechanism which pops the toaster up (look for the mechanism attached to the tray in which the toast lies). There should be a spring, or remnants of a spring, which should be fairly easily replaceable with a similar spring. This should be readily available from your local appliance spares store.
Please let me know if I can help any further or furnish you with more details. As your toaster is very old, it will be too difficult to find any documentation on the specific model.
Best wishes,
Graeme.
Jan 06, 2012 | Toastmaster Kitchen Appliances - Others
Repair of 1939 Toastmaster Toaster Model 1b6
remove bottom plate.....remove 10 screws holding the bottom brown plastic base...loosen screw under push down lever....romove light, dark knob small center hex screw....cover will now lift off....gently....watch #20 toast "wires"
May 04, 2009 | Kitchen Appliances - Others
The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Apr 05, 2009 | Dualit CTS4E 4-Slice Toaster
Manual for breadmaker
http://www.retrevo.com/samples/Toastmaster-manuals.html
link for toastmaster manuals
Feb 23, 2008 | Toastmaster 1148X FastBake Bread Maker
Toast Master Toaster TP409
if you mean the toast itself doesn't toast on one side, check that both heating elements have about the same resistance value. One could be twice as conductive as the other and not heat as much as the other side.
If you mean the other two slots don't toast, the problem could be in the switch or in the elements themselves. check carefully the continuity of the toaster across the (unplugged) ac power connector while you push the toaster load handle down on each side. If the resistance is significantly larger on the problem side, the problem is either the switch or the elements. The problem is usually with the switch becoming corroded or oxidized. The switch is supposed to be self-cleaning, that is, it wipes itself as contact is made to help remove buildup. Sandpaper both contacts until they shine copper colored. Otherwise look at the elements while toasting. dark areas mean lower wattage is being dissipated and the element may be bad near a dark spot.
Nov 26, 2007 | Toastmaster TP409 4-Slice Toaster
Kitchen Appliances - Others Logo
231 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
troup
Level 1 Expert
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
