Question about Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4" ultra-slim HDTV
Vizio e420vse It has worked fine for just short of a month with great picture and sound. Now I moved back to school, plugged it in, and it has worked well for almost a week. This morning when I powered on my tv I received audio but no video picture. Powered on and off multiple times, same thing. Now I just have a short blink of the white indicator light, no display, no sound. It appears to not power on at all. Any advice?
  • 33 Answers
Its the led driver board in upper left corner. Replacement board hard to find
Posted on Jan 18, 2013
  • zdkoenig
    zdkoenig Jan 18, 2013
    Yeah, it's being replaced by Vizio. Provided my proof of purchase from Costco and it's under warranty obviously. Sending a certified set out in 5 to 7 days. Free, thankfully. But no australian open or movies until then.
  • 1,238 Answers
If your TV is under warranty you have to contact the store where you brought it..
Posted on Jan 17, 2013
  • zdkoenig
    I called Vizio and they are sending me a certified tv set, same model. Free of charge, but it's a week of no movies for me. Really irritating but it could be worse, like out of warranty.
kidsasuke
  • 121 Answers
SOURCE: no sound and no picture
It may well be the power supply. Filter capacitors have a nasty tendency of blowing, as well as voltage control ICs. If the filter blows, you end up with a shaky DC signal that can't be effectively used by digital components (which make up about 80% of modern TV circuits). If you're within warranty/exchange then go for the manufacturer. If not, and you're comfortable with opening these things, then you can carefully (after unplugging and allowing it to discharge) take a glance inside. If any capacitor(s) are visibly blown out, then there's your problem.
Posted on Jun 03, 2010
  • 87 Answers
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Posted on Oct 23, 2007
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
Angel Petter
  • 114 Answers
SOURCE: Vizio L37HDTV10a, No picture, Sound works fine.
maybe its the Y or X Sustain its depends on your picture
Posted on Feb 10, 2010
Vizio tv model e420vse turns on and then screen goes black. Still has power and sound. If I turn off and back on, the picture will come back for a few seconds and then shut off again. Vizio suggested it...
There are a lot of references on how to repair the LED backlight. If you can source the parts, google search LED backlight repair.
You may wish to read this first: http://www.techlicious.com/blog/un-repairable-vizio-tvs-leave-customers-out-of-luck/
Mar 31, 2015 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
Do you have vizio E420vse schematic?
sounds If the set gone into stand by mode. You could try switching it from standby mode. that's if you haven't damaged board.
check power to board while pressing standby.
Jan 20, 2015 | Vizio 42 in. LCD TV
Is there a way to fix a vizio e420vse that doesn't power on?
Most have a fuse in side other than that off to the repair man, get a quote as it could cost a lot.
Nov 13, 2014 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
My vizio e420vse wont turn on
Did you check the fuse? Do you have 5volt standby power?
Dec 18, 2012 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
LCD TV Has Sound, Backlights Work, but No Picture
I have been having the same problem with my LG. people say there are bad capacitors on the power supply board. I don't have the know how to replace them and don't have the money to pay. I can get mine to work by blowing hot air with a hair dryer into the back of my tv through the vents over the board. Heat it up for a couple minutes and turn it off and then back on and the picture comes back. I just never turn the set off now.
Sep 08, 2012 | Vizio M550sv 55 Inch Class Edge Lit Razor...
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
VIZIO HDTV picture half fully green
tv crashed.has computer inside this happens sometimes
Feb 18, 2010 | Vizio SV370XVT TV
No picture on vizio lcd
It's likely not a backlight, but a mainboard. If you are feeling frisky, take the back off and get the model number off the mainboard and check eBay.
Jul 26, 2009 | Vizio P42HD Television
Television will not turn on
My 47" Vizio wouldnt turn on this morning.....had a similair problem 3 yrs ago.....this is what i did and fixed the problem myself.....apparently you have to reset TV. Here is what has worked for me. So unplug tv power cord from the tv. Hold the power button and imput button together ( located on side panel ) for approx 45 sec......plug cord back into tv. Press power button on tv and voila !!!!! Tv came back on!!! I have had my Vizio almost 5 yrs. But have to call the unhelpful customer service atleast once a year.... I hope this works for you :)
May 03, 2007 | Vizio L32 32 in. LCD HDTV
Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4" ultra-slim HDTV Logo
505 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
