Question about Garden
Oil leaking out of reverser dipstick - Garden
  • Garden Master
  • 14,378 Answers
Clean air filter and check muffler.
Posted on Jan 18, 2013
1992 cadillac deville leaking oil at dipstick
I would look for other leaks. If you are sure it's leaking at the dipstick tube, there is normally an o-ring where the tube presses into the engine. In general, this is an odd place for a leak, as ther eshould be no oil pressure in the pan (where the tube terminates) and unless the engine is overfilled with oil, the tube end shouldn't be immersed in oil to leak. IF there is pressure in the oil pan, that generally indicates bad rings. I have seen engines where the oil dipstick actually pops out of the tube under pressure when the engine is running due to pressure in the oil pan from blow-by at the rings.
Jan 05, 2014 | 1992 Cadillac DeVille
Oil leak from dipstick
You don't give the make model and year, but I would say you are right in your guess the problem is venting. The hose to the air cleaner could have frozen closed for one example.
You could damage the engine bearings and the oil pump running the engine low on oil.
Jan 04, 2013 | Cars & Trucks
2000 ford excursion...when i go over 65mph the transmission starts 2 leak & i see a trail of smoke behind me...now i need a new dipstick housing because it just broke half way up....could it be leaking...
Sounds plausible that if the dipstick housing is broken, has a crack or hole that fluid could come out and drip on the exhaust manifold causing smoke. This works similarly to an oil dipstick, if you check the fluid cold and notice where the oil is on the dipstick then start the vehicle and shut if off and check the fluid again the oil will be higher on the dipstick (pressure).
I hope this helps!
Nov 06, 2012 | Cars & Trucks
First thing in the morning, putting the car in reverse or drive after starting, the auto transmission makes quite a large bump. When warmed up the transmission is quite smooth when changing from drive to...
Hi no dipstick on these models there is a level screw on the bottom of gearbox,its a big allenkey with a small one inside if the small one is removed the oil must come dripping out if not the level is lower than the big level screw note do not remove big screw then all your oil will leak out and make sure the car is hot when u check oil level to get rite level.A other thing is I no there is software updates on the gearbox control units so if the oil level is ok get the car scanned at a dealer to check for uptades.hope this helps.regards
Jun 30, 2011 | 2005 Volkswagen Golf
I just bought a 96 plymouth voyager 3.3 with 277, 976 miles on it. there was no check engine light but i ran a diagnostic and it said gear 1 ratio incorrect. it does slip at times and after about 20min or...
First, get a correct dipstick, you cannot verify levels with one that is not the right height-with all those miles, I almost be afraid to do a trans service, but the codes you are getting are because the trans either has plugged passages in the valve body, or you have issues with the shift solenoids-worst case you might end up putting a used trans in it, they are not alot and can be found everywhere.
Mar 14, 2011 | Plymouth Voyager Cars & Trucks
2006 chevy aveo. the dipstick reads oil is full. but there is oil in the spark plug holes.did the mechanic overfill last oil change. that was 4000kms ago. dipstick still reads full oil
You have oil in the plug holes because the seals that are supposed to keep oil out are leaking-you need to remove the valve cover to replace them.
Jan 06, 2011 | 2006 Chevrolet Aveo
Vr commodore takes awhile to go into reverse
if it isnt low on transmission oil your reverse gear solinoid needs to be changed take but i suggest you check where your leak is comming from id say it would be tha pan gasket
Apr 12, 2009 | 1997 Honda Passport
1995 subaru legacy - transmission fluid dipstick?
The Dipstick is on the driver side right next to the starter and yes you also put the fluid in there.
Dec 19, 2008 | 1995 Subaru Legacy
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
