Question about Epson Expression XP-305 Inkjet Multifunction Printer - Colour - Photo/
Epsom xp 305 wont print text documents
We set it up , its wireless but we are using it via usb lead.It prints pictures from a memory card put into the printer but when we try to print a document from the laptop it wont print anything or say it wont. It asks us to save it as a xp file.We try to print the xp file but again nothing happens. It is recognised by the laptop as when installing it it said the product was recognised.Please can you help
  • 4 Answers
SOURCE: Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
Posted on Jan 26, 2009
nyilasrobert
  • 627 Answers
SOURCE: Epson fx-2175 not supporting Times New Roman font in PDF document
i suggest to update your acrobat reader to a better version (e.g. 8)
As i know acrobat 7 has some font issues which you described
Posted on Jul 27, 2009
SOURCE: I have an Epson stylus sx205. When I try to print
My Epson SX205 shows ink cartridges empty, when they are not and or does not recognise them as being compatible. Is there software available to over ride this problem
Posted on Oct 30, 2009
  • 133 Answers
SOURCE: Cannot print documents wirelessley from SX515W
in vista as with windows 7 you must tell the computer to connect to your printer in network preferences. It wont work untill it is told to connect!
Posted on Jan 01, 2010
  • 33 Answers
SOURCE: I have an Epson LX-300 Dot Matrix Printer
be sure that the lx300+ you are installing is in current setup. it should work if it indicates the the epson lx300+ is the default printer.
Posted on Sep 24, 2010
Can i print from my computer without the usb 2.0 cable
To print documents from your computer you will need to have it connected via USB. If you just want to print pictures you can load them on to an SD card (or any of the other supported cards for this printer), plug the card into the printer's card reader and print directly from the printer.
If you want to be able to print without using USB you should look into wireless printers such as the Kodak ESP 7250.
Mar 07, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
My Panasonic DMC-F562 Lumix Camera will not download copies of pictures into a file in my computer. I can print and then scan then get a picture via the memory card only. It says check connection but if...
You have not said if you have tried putting the memory card in a card reader, either built-into your PC, or plugged into a USB socket on the PC. The PC should then open the memory card and you can copy or drag and drop images directly onto your PC. If it does not happen automatically then double click on the card's icon in My Computer to open it. I presume you had the problem when you tried connecting the camera to PC with the supplied lead. (the camera needs to be powered, and perhaps also in the right mode for file transfer and connected when you switch the camera on). If this does not work according to the Lumix instructions and you don't have a suitable card reader you could try uninstalling and reinstalling the Lumix software on your PC.
Dec 11, 2010 | Cameras
Able to print documents on HPc4385, but cannot print photos
When you were connected with a USB cable was it connected to the computer your using as local? Are you using a wirless print server? Possible corrections are in the properties of your print setup. You can change the spooling properties to print immediately to require less memory.
Aug 30, 2009 | HP PhotoSmart C4385 All-in-One Printer
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
Epsom RX620 Poor quality photo prints
I have got round this problem by routing my pictures via Picasa 2. Printing direct is still a problem, but I think I can live with that for now.
Richard
Nov 18, 2008 | Epson RX620 All-In-One InkJet Photo...
HP Laserjet 3550
double check ALL the print settings (i.e. paper type, document type, etc). Depending on which option it is even one "box" or "setting" being changed can alter your printers function. Try looking for options that will auto detect the type of document you are printing (ie, color, with pic, plain, etc).
Jun 12, 2008 | HP DeskJet 3550 InkJet Printer
Sharing HP PSC 1410V All-In-One
Yes, you can and it is pretty easy.
You should get the HP Wireless Printing Upgrade Kit
(Q6236A#A2L)
Price: $69.99
Here is there product description from HP.
Get everything you need to print wirelessly in this simple upgrade kit! It includes a printer receiver and PC receiver for a wired desktop or notebook PC, and it's easy to both install and use.
Works with most HP printers and All-in-Ones, plus all PCs, wired or wireless.
* Print from virtually anywhere in your home or office via the wireless 802.11g connectivity
* Eliminate ugly cable clutter but still get the same print speeds as via USB
* Retain full all-in-one wireless functionality: print, fax from your PC, scan, and access photo memory cards access and PC status
* Set up fast: just plug the receivers into your printer and PC; there's no configuration
* Protect your signal from interception with the secure wireless connection
* Use with a network, or just one PC
* Compatibility: most HP printers, all PCs (wired or wireless)
** I checked and your HP is on the compatibility list - it is ok***
What's in the box?
1 printer receiver
1 PC receiver
William
Feb 15, 2008 | HP PSC 1410v All-in-One Printer
No printer information
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
You need to use a program that can do printing multiple pictures in just one click.
Feb 05, 2008 | Epson Stylus Photo R200 InkJet Printer
Lexmark X4850 wireless set-up
I have a Lexmark X4850, every time I print a job it prints a blank page first then the document. I have tried to tell it to print 1-1 or 1-3 but it continues to print that blank page first. any suggestions.
Oct 05, 2007 | Lexmark X4270 All-In-One InkJet Printer
Epson Expression XP-305 Inkjet Multifunction Printer - Colour - Photo/ Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
