ALL THE CHANNELS TO PLAY
HAVE A 32LG30 HDTV HOOKED TO DVR BOX CAN'T GET ALL CHANNELS TO PLAY
  • 362 Answers
From the tv menu make sure the tuning band is set to CABLE and not to AIR/Antenna.
You may also have to do a Auto Channel Search.
Let me know if this helps and please rate this solution.
Lone99star
Posted on Jan 25, 2009
All channels have dropped out
Unplug,replug the tv and cable box about hour later.The cable box should upgrade it software and the tv will reset itself back to factory setting.The tv now,should work again.
Sep 05, 2010 | LG 32LG30 32 in. LCD HDTV
I have it hooked up to the cable dvr with a hdmi
You don't need to scan for channels if it is connected by a HDMI connector, just select HDMI 1 or 2 depending which one you have connected the cable to at the rear of the TV. You should now receive the already set channels from your cable box.
Sep 24, 2009 | LG Televison & Video
32LG30 LCD TV screen aspect 4:3
I went into options or menu on LG remote and checked 480i and it worked.
Jan 10, 2009 | LG 32LG30 32 in. LCD HDTV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Audio Problem on a Pionneer DVR-810H Recorder
Thinking the problem might be the cable box..I bypassed the Tivo and hooked the cable box direct...there was audio on ch. 3 ....reconnected the Tivo and the audio was fine...strange?
Thank you.
Ken Havel
Greenville,WI
Oct 10, 2008 | Pioneer DVR-810H DVD Recorder
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
HDtv picture and av reciever sound do not match
I have a hdtv hooked up with a virgin v+ box but slight delay Why?
Dec 06, 2007 | Televison & Video
Sony RDR-GX300 DVD Recorder > cant progamme channels to record
is the dvr burner hooked up to cable directly or is it coming from a cable box through video cable or again from coaxle cable?
Nov 24, 2007 | Sony RDR-GX300 DVD Recorder
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
