Question about Drills
Can't find a maual for a draper bench drill mod no;GD16/12 NT2 TAPER.12 SPEED 16MM CHUCK CAPACITY
  • 10865 Answers
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
Editor925
  • 285 Answers
SOURCE: ryobi spare parts
Unless you have the part in hand, which you could take to a specialized machinery or spring supplier to see if they could match it up, the only other way to get the correct part is to contact ryobi direct and talk to their parts department. They will be able to tell you the part number, and if available, send you one out direct from their warehouses.
Good Luck!
Posted on Sep 04, 2009
Testimonial: "Thank you very much for taking time to help! I have phoned Bunnings who I think are now the only suppliers of Ryobi in AU who are sending a spare. "
rowdy45176
  • 2176 Answers
SOURCE: Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
Posted on Oct 08, 2009
al_kupchella
  • 843 Answers
SOURCE: i need a chuck wrench/tool for a duracraft drill press
Are you talking about the chuck key? That's the little wrench with a collar of gear teeth on it.
There are only a few standard sizes plus a couple of odd-balls. Last time I looked, Sears carried a good selection. If you have the old one, take it with you to the store. If you don't have the old one, find a way to measure or approximately measure what you need. Another chuck key that doesn't fit can be a useful reference. If you can find something (maybe a drill bit) that is a close fit into one of the three holes in the chuck, that can be useful too.
Posted on Jan 19, 2010
SOURCE: can't remove the chuck on my mastercraft drill press.
I just bought the exact drill press #55-5917-0 and I had to assemble it . The shaft that the chuck is on is tapered and the chuck is tapered on the inside , so you will have to put a wedge on each side of it and lightly tap on the wedges until the chuck drops out.
Posted on Aug 14, 2010
How to fix a out of round drill press chuck (ToolKraft 350B
The chuck could be threaded like an average power drill.
Respectable drill presses use a hollow quill shaft that is likely to be machined into a taper that is likely to be number 1, 2 or 3 Morse taper.
Morse taper drill bits are used a lot - the shank is tapered and will grip and drive when inserted into the quill with just a small force. When the bit is to be removed the quill is turned by hand until a slot in the quill lines up with a slot in the housing and a wedge-shaped steel tool is slid in and tapped breaking the taper fit.
Most such drill presses are supplied with a chuck for light duty drilling already mounted. The chuck is often a Jacobs type mounting by means of a Jacobs taper onto a Morse taper adaptor.
The adaptor is tapered at both ends - at the lower end the taper is steep and the chuck must be pressed on with some force. The upper end will have the same gentle taper of the Morse taper drill bits and is removed in the same way.
Using the chuck drilling is limited to the capacity of the chuck, typically 1/2" or 5/8" unless blacksmith's drill bits are used that have stepped shanks.
Morse taper drill bits will allow heavy duty drilling far in excess of the chuck capacity.
Hopefully your problem is caused by the chuck rather than a bent quill.
Dec 03, 2017 | Drills
Removing chuck from a sears & roebuck model 113.24611 drill press
It is a morris taper wedge fit, so just tap it out.
Dec 29, 2016 | Sears Drills
How do I make the spindle chuck stay in the quill of my model FDM 16 SPC drill press? I have forced it down on a block of wood. It will stay for a while that fall out.
16 speed should have a Morse taper
for the std drill chuck
to fit a different chuck the morse taper needs to be emery sanded
and the replacement chuck should stick
after using the wood block pressure press method
if not you need a new morse taper for that spindle chuck
hint
i had my drill accuracy and off center spin tolerance down to one thou
with stretched old belts I got more speeds than 16
for special jobs
my 16 speed used a morse taper two for the drill chuck
this picture says its a spindle chuck
26313356-3kt1rk2qq1yye1uaamrjudob-5-0.jpg morse taper
Oct 16, 2016 | Drills
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    What is the size of the taper on end of the spindle that takes the Jacobs chuck?
    if it is in a pedestal drill with a 1/2 inch chuck it can be no 1 morse taper if that is too small as some drills have capacity for larger chucks the there is a no 1 to no 2 adapter sleeve available
    Nov 09, 2015 | Drills
    How do I remove the chuck from my drill press
    Need to know what make and model drill press you have. You could have a taper or a threaded chuck setup. If threaded it would turn opposite drilling rotation and the may be a screw inside the chuck that needs to be loosened/removed and if it is a taper you need a removal tool to pop it out with.
    Sep 21, 2014 | Drills
    How do you get a morse taper chuck out of a guardian power 12 sp drill press
    Everywhere there is the same kind of remove or by a long axle insite the top pulley down
    How To Remove Morse Taper Mounted Chuck From Drill Press AutoDrill
    Mar 17, 2013 | Delta 15 331 15" 115/230V Variable Speed...
    Would like to replace the 3/4 Chuck on Jet Drill Press
    Grizzly sells a nice variety of quality chucks at good prices. Look at the numbers on the chuck you have to determine what to buy. You should remove and re-use the taper from your present chuck. You probably have a Morse #2 taper up into the spindle like the picture shown below. I assume you know 92bb256.jpghow to get that out of the spindle. What is not shown in this picture is the taper that is inserted into the chuck. This is probably a Jacobs taper. To separate that you need to support the chuck in a vise with the long taper pointing down. Put something below it to catch it without damage when it falls out. Open the chuck as far as it will go. Get a bolt (about 3/8) that you can hit with a hammer inside the chuck straight down to knock the taper out of the back of the chuck.
    Apr 12, 2010 | Jet 354170/JDP - 20MF 1 Drilling Capacit...
    I have a model 1689 drill press with a 33 taper jacobs chuck I need to remove the chuck to put a larger chuck on is the smaller chuck threaded on and if it is, is it RH or LH thread and how do you hold the...
    you dont hold it, the chuck is a taper fit and you would need wedges to remove it. the newer chuck would also have to have the same taper to work. if replacing the new chuck you would need to make sure the parts are clean, use a brake cleaner and a paper towel to clean them and then they would press together. Let me know if you still need more assistance.
    Jan 13, 2010 | Speed Clausing 15" Variable Floor Model...
    PRO- TECH DRILL PRESS BENCH MODEL
    parts can be found on amazon, take a look here: Amazon com Drill Press parts. I hope this was helpful. Cheers
    Jul 19, 2009 | Delta 15 331 15" 115/230V Variable Speed...
    Drills Logo
    53 people viewed this question
    Top Drills Experts
    Are you a Drill Expert? Answer questions, earn points and help others
