Question about Refrigerators
My frigidaire gallery series refrigerator water dispenser not working. (14 months old). Ice maker and water to filter ok. Seems to be blocked in the door. I tried to unblock with wire running up disp
Model FGHC2345LF2
  • Steve Toton Jan 18, 2013
    Model is FGHC2345LF2.. Water seems to be blocked behind door. Diagram shows it should be a clear tube to bottom of door. Should I try to defrost the door
ctf1800
  • 4402 Answers
SOURCE: ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Posted on Dec 08, 2007
SOURCE: Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Posted on Sep 20, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Why don't the water dispenser and ice maker work?
You're on the right track. Clear the line, and it will probably work.
May 18, 2015 | Frigidaire FGHF2344MF Gallery 22.6 Cu. Ft....
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
My ice maker dont make ice
Please ensure that the water filter has been changed. If you are not receiving water to the dispenser it may also be a frozen water line and will need the assistance of a Service Specialist.
Jan 05, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
hi there,
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series M# GLHS36EESB5 S#LA53808237 The indoor water dispenser stopped. I replaced the filter but nothing changed. The fridge is 18 months old.
check to make sure there is nothing blocking the water lines and no kinks in the water lines, you did not say if it had an ice maker, and if it is affected.
The frigidaires also has a plastic tube coiled under the back to dispense cold water make sure this tube is not kinked.
Hope this helps
Jul 02, 2008 | Frigidaire Refrigerators
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
