WASHER FILLS WITH SEDIMENT AND DESTROYS CLOTHES
WASHER FILLS WITH SILT AND RUINS MY CLOTHES, I KNOW IT'S NOT MY WATER PIPES I HAVE ALREADY HAD THEM CHECKED IS THERE A FILTER I NEED TO CLEAN? My manuals are missing.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Do a wash with no clothes in a hot wash only
Posted on Jan 18, 2013
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
onthejob5130
  • 640 Answers
SOURCE: LG front load washer has blocked drain line which is located in
take top off remove three srcews in back ..remove 4 screws hold control console ,,dont remove connection just flip console on top of drum,,make sure unit is unpluged..your looking at 4 screws across to panel remove them open door remove spring wire clip around the out sid bellows where almost there..now careful down in the filter acess panel remove the frist screw the filter cover comes off after the cover is out remove the pump filter housing screw..and last remove thebottom panel screw,,remov panel,,pump on left is drain pump..pump on right is recrulation pump
Posted on Dec 25, 2008
MNTECH
  • 1543 Answers
SOURCE: Water Surge Making Pipes Knock
What you are describing is called "water hammering" and is caused when a water valve shuts off quickly. The momentum of the water moving within the pipe causes the pipe to bang when it comes to a sudden stop. Plumbers can install an air chamber to absorb the water hammer (just like a shock absorber) but you might try ones that you can just screw onto the hoses behind the washer. I have seen them at places like Home Depot in the plumbing department. (hope you can find someone who actually knows what you are talking about to help you find them) Alternately, you may be able to find them at a hardware store or appliance parts supplier.
Posted on Feb 01, 2009
  • 5 Answers
SOURCE: Water drip into washer, used to gush in. Now water pipes bang, whine
The problem is the 10 cent rubber washer in a shut off valve in your plumbing. The brass screw that holds this washer has corroded and the washer has come loose. It now floats around inside the valve and the water flow can be blocked at one time, whistle, howel and make bangs at another. It could be any valve including the main shut off. You can listen to the pipes but the sound travels, so you are looking for the loudest spot. A new washer and screw could fix it, but sometimes the screw is broken off requiring a new valve stem. Be prepared to replace the whole valve.
Posted on Dec 19, 2010
  • 489 Answers
SOURCE: On the LG Tromm front
You have a broken drain pump and it will need to be replaced.
Good luck
Posted on Jun 15, 2011
What would cause a circulator failure?
I am going to assume the circulator pump is on a hot water circulation loop. Turning the water back on could have stirred up the sediment that has collected in the bottom of the water heater. This could clog up and possibly ruin the impeller. Running for an extended period without circulating water can overheat and damage the pump also. It is a good idea to hook a hose to the water heater drain and flush out the sediment periodically. Hope this helps.
Jan 18, 2014 | Bell & Gossett 103252LF NBF-22 Circulator...
Ge front loading washer drum fills with smoke at end of last rinse cycle and smells of burning rubber
THE INNER DRUM IS BAD WITCH LETS IT RUB THE FRONT SEAL OF THE WASHER YOU NEED TO SEE IF YOU CAN MOVE THE DRUM UP ARE DOWN ARE SIDE TO SIDE IF SO ONE OF THE SUPPORTS ON THE BACK BROKE AND THE GET THE SMELL OUT WASH THEM IN WHITE VINAGER
Oct 31, 2012 | Kenmore Front-Load Washing Machine 3.5...
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
After tank fills up, water continues to flow a little. How do you fix it?
Is the water flowing into the overflow? If so adjust the water level. Have you checked the shut off seal inside fluidmaster? If you just installed could've jogged some sediment lose in the line and plugged the seal if older could have a bad seal.
May 25, 2011 | Fluidmaster & Fits-All Faucet Connector
My maytag neptune will not stop filling with water at the initial fill cycle and will eventually push the door open and empty onto the floor. The water never turns off, even if I unplug the machine, water...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
There is a screen filter in the water supply hose that may need cleaning. A recurring problem like yours is usually caused by sediment in the water which prevents the valve from closing. It's usually just the cold water side because the hot water has a chance to settle before being used. . Being on a well water system or a system where the pipes have been disturbed from repair or construction can cause extra sediment.
Jan 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water pipes vibrate very loudly when the washer fills with water
Possibly a bad inlet valve solinoid that is not opening completely. Unfortunately you will need to have a F/P tech out to look at it.
May 22, 2009 | Fisher and Paykel Fisher & Paykel Washer
Kenmore washer. At rinse cycle only, water fills very slowly.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 06, 2009 | Kenmore Washing Machines
Kenmore 90 Series fills so slow on rinse cycle
3. On the washer side - look for a removeable screen inside where you just removed the hose.
8. re-try.
Feb 09, 2009 | Kenmore 15944 Top Load Washer
I have a maytag washer # LAT 9593 , washer fills with water very
Take off your hoses and check filters for sediment build up. If this is ok, you may need to replace the water inlet valve.
Feb 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
